Results 1 to 2 of 2
    Veteran Member Three Rings rkern's Avatar
    Jul 26 2012
    93 Corrado VR6
    SoMD
    ABS Sensor Part Number Help
    I snapped the head off the front ABS Sensor bolt doing wheel bearings. I was able to the sensor out but I need to get the broken bolt out and replace it. I may end having to do a helicoil and I need to know the size of the stock bolt. Does anyone know the part number for the bolt that holds the sensor in? ETKA isn't real clear, shows sensor but no bolts. I have seen press in sensors but that doesn't help me.
    01.5 S4 Avant Imola Yellow Stg 3
    93 Corrado VR6 3.0L
    Jul 04 2012
    Woodbridge, VA
    Best bet is to pull a different corner and take it to hardware store.
