Results 1 to 19 of 19
    Aug 05 2014
    Westchester
    RS5 with awe downpipe and stock exhuast
    Hey Guys,
    I'm looking at my exhaust options and since I'm already dropping a pretty penny on suspension I have to see what i can get. I recently heard awe non resonated dps with the sport exhaust sound sick.
    Has anyone on here done this before ?
    I want to keep my valve system until i get another full exhaust.
    Jul 25 2011
    yes I have done it, really impressed with the sound!
    Aug 05 2014
    Westchester
    Quote Originally Posted by Beast View Post
    can I SEE A VIDEO...I think I saw you on IG ..Does it drown alot ?
    Jul 25 2011
    Quote Originally Posted by NYCB8S4 View Post
    Sure i will upload one, no drone at all! Id say 60-70% louder valves open vs stock sports
    Aug 05 2014
    Westchester
    I'm excited cause I def didn't feel like dropping 3k on exhaust... The non-res are around 700 right ?
    Jul 25 2011
    contact Mops@supremepower he will give u a good deal
    Aug 05 2014
    Westchester
    Great.. I just sent them a message.. Now let me hear this video =)))
    Jul 25 2011
    here u go mine vs an RS5 with a custom full 3 inch exhaust....
    Junior Member One Ring
    Apr 23 2017
    Florida
    Hey, just curious on your opinion, was it worth it getting the AWE non res downpipe with the sport exhaust on the rs5? and how much was it to get installed and all? thanks!
    Mar 15 2017
    Austin TX
    Quote Originally Posted by becahm28 View Post
    Would like to know this too - didn't know it would fit with stock exhaust.
    Also was there ANY power gain from this?
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Resonators typically won't create a restriction so there's no gains to be had by removing them. If the welding/transition is really bad, sure, there can be a gain. But adding or subtracting a resonator isn't really going to make any difference. High flow cats or cat delete would be the way to go (although for the record I don't believe in deleting cats). Those'll make measurable gains with the stock exhaust.
    Jul 25 2011
    Quote Originally Posted by AsherAudi View Post
    yes definitely worth it. sound alone
    Aug 05 2014
    Westchester
    I was def going to do this but ended up landing a sponshorhip with meisterschaft and couldn't pass up on the deal.
    Jul 28 2007
    RS5
    gta, ontario
    There are gains in getting rid of stock dps as they are very pinched in parts compared to aftermarket dps
    Mar 15 2017
    Austin TX
    Quote Originally Posted by spa View Post
    Ok I'll bite, then what about high-flow Cats - who makes the best ones and cost etc?
    Jun 24 2017
    San Antonio, TX
    HFC's would necessitate engine removal unfortunately, they're hard to get at. The catalytic converter is going to offer far more of a restriction than the OEM downpipe itself, even with the dimples and flattened areas. Downpipes for sound? Most definitely but you'll feel no real gains. I'd be shocked if the downpipes showed more than a 1-3 whp gain, well within the realm of the dyno's fudge factor.
    I haven't seen any that are readily available. I know GMP is working on that header/cat setup but again, you'll have to drop the whole engine for installation.
    Jul 25 2011
    Awe tuning makes the non res Downpipes that attach to the stock catback. The Downpipes for our cars do not have CATS they are up near the headers so you don't need to worry about that
    Mar 15 2017
    Austin TX
    Thanks I guess in order to get some real gains using stock exhaust, I'd need to find a set of the sick Kline Headers (requires dropping the engine to install), then stick on some high-flow Cats and new downpipe at the same time. Won't be easy finding those headers now that they're discontinued :(
    Apr 23 2017
    Florida
    what does it sound like with the flaps closed? I saw a video here on audizine with flaps open with the downpipe and it sounds nice but couldnt find one closed
    or you got a video of yours?
