Results 1 to 40 of 68
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    EPC on EPL E85 Stage 2 Tune
    Anyone else getting it? Not sure if its ambient temp related and Ethanol content related... But I started getting them daily for the last two weeks. That coincides with the temp increase here in Texas. Soooo annoying!
    Quote Originally Posted by GRUMPY-S4 View Post
    Yup...but only if my e85 is out of percentage range. In the summer here in Las Vegas, the e85 jumped from 75% to 93%. Which can easily trip car thinking the fuel composition is off. My suggestion is get the carista app and dongle and run fault codes to see if you're running lean. Then, if your way high which you probably are, throw in 3-4 gallons of regular gas to bring down the percentage. Your testing your fuel right??
    Unfortunately this is the price you pay running e85 on a car that is not meant for it.
    Nov 16 2015
    DFW
    I have the Ethanol reader... Im at E82
    Hmmm. Should be almost perfect. How often does it happen and what codes are thrown??
    Jun 28 2016
    US
    Can you please read the codes via VAGCOM and report what they are?
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Maybe related to your fuel pump again?
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Quote Originally Posted by fitzydude View Post
    What was wrong with the pump?? Low pressure one or hp?
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by derek.kritz View Post
    He had issues with the Autotech upgrade (parts) the first time.....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Ahhh. Got ya.
    Nov 16 2015
    DFW
    I havent checked codes... Its happening daily on my commute... Just cruising at highway speed. I dont even pull over anymore... I just shift into N and restart
    Nov 16 2015
    DFW
    I will pull the codes this weekend
    Senior Member Two Rings Shantb13's Avatar
    Jun 22 2014
    2002 vw jetta station wagen
    Fullerton , ca
    Are you on stock fuel pump ?
    Nov 16 2015
    DFW
    Quote Originally Posted by Shantb13 View Post
    Nope... Autotech
    Nov 16 2015
    DFW
    Now I got a CEL... Fuel Trim Code 0171
    Arghhhh!!!!!!
    Arghhhh!!!!!!
    I get that one on hard runs and when my E85 isn't perfect percentage. Never actually through the code, just soft ones.
    Nov 16 2015
    DFW
    I had not gotten an actual CEL until now. What has Tony said about this? We are SOL or says its a Hardware issue?
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I think my recent idle code could be related to yours. Possible vacuum leak instead of low fuel supply (although it could be the case since e85 varies. Fyi, I replaced the evap check valve and fuel cap. So far so good although I am crossing my fingers.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Aug 23 2015
    Texas
    Quote Originally Posted by Hofahome View Post
    This is a very good possibility. Also, you may want to try clearing the code and log your fuel trims.
    Nov 16 2015
    DFW
    Quote Originally Posted by omegis83 View Post
    Im pretty sure my code is fuel trim related. In my opinion this car isnt meant to run E85 and I was kinda sold i to the idea that it could. I guess the question now is... Does running it with the whacky fuel trims affect the car? Would I be better off running an E70 mix?
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Come to the dark side. at your age you need the classy part just as much. Sleeper mode is good enough for the older crowd. But knowing you, not going to happen lol.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Nov 16 2015
    DFW
    Quote Originally Posted by TexasDfwS4 View Post
    I like flashy lol
    Nov 16 2015
    DFW
    Kind of Frustrated that I went with this tune to use E85 and paid the extra money for the tune and hardware and my issues are not addressed.
    Sep 10 2012
    DFW
    I hear you, that's why I went with Unitronic. Uni has a good rep and has been around for many years. Their not the fastest but they have all the safety measures still in place.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Please let me know how I can help.
    Have you flashed the latest file?
    Tunes do not "change" over time. You had issue in the beginning, the you replaced the fuel pump and most/all went away. You then drove several months with out a CEL and now have one.... Neither case I believe tune related. If the tune"works" and then you get a cel, it generally not the tune.
    Again, please make sure your up todate.
    Nov 16 2015
    DFW
    Quote Originally Posted by Tony@EPL View Post
    I will check what file is on the server and flash today.
    I agree that tunes dont change but conditions do. Fuel in summer can be different... Weather... Etc
    Keep in mind my EPC and CEL have both been while just cruising around as I havent really been "on it" lately.
    May 06 2004
    W124s
    PA
    I noted the same issue with mine. Seemed to trigger the EPC light on steady state cruising, usually up a slight hill when I'm just following traffic around 45 MPH, or cruising on the interstate. I could deter it by varying the throttle on hills where it seemed more prevalent. I couldn't make it 10 miles home otherwise with having to restart the car. I diluted the ethanol with a few gallons of 93 and it seemed to help fuel trims, but the EPC issues with the fuel measuring system 2 fault were unbearable. Flashed back to the gas stage 2 file and all good for a tank and a half. Trying the new stage 2 E85 file today with fingers crossed.
    I'm somewhat suspicious of the high pressure pump though. On stage 2 gas with the HPFP upgrade, fuel trims look about perfect. I would think it should need to lean it out a bit... Although the electric pump is only requesting about 25% so perhaps that is where the difference is made? Idk.
    Keep right pass left, it's the law!!
    You might be onto something with the weather. It never happened to me until it got warmer. And of course the e85 went WAAAY up in percentage. I've figured it out that getting it down to about e70-e75 eliminates all trim codes and I haven't had an EPC experience in about 3 tanks. Every car seems to me much different an how it handles the alcohol.
    Nov 16 2015
    DFW
    And thats the point I have been trying to make here. A tune may work for some but not for all.
    I will flash the new files and start filling with the Racetrack E70 stuff to see if that helps during the summer
    Jan 26 2015
    CO
    Interesting. I cannot seem to get better than e66 where I am at, even in the summer. I have not had your code.
    Nov 16 2015
    DFW
    At E66 you probably will never get the code... Although you are right at the low end of where the tune is supposed to operate. I believe its E65 and above.
    Seems high heat plays a part in how high your e85 can go. Car likes less purity when temp increase.
    Nov 16 2015
    DFW
    I think you summed that up well
    May 06 2004
    W124s
    PA
    I've flashed back to the latest stage 2 E85 file.... Knock on wood, so far so good! May be too soon to tell for sure since I only have about 150 miles in, but so far the only code that's come back is the engine over speed fault due to the dsg tune. Fuel trims are still looking good, still a bit higher on part throttle, but not enough to trigger any faults yet. Using the vial test method, I'm using E90ish. File feels strong too, keeps pulling hard over 100 where it previously felt like it flattened out.
    Jun 28 2016
    US
    Quote Originally Posted by quickglx View Post
    You should not be getting that engine overspeed fault code. Not if you have a proper ECU and TCU tune. It shouldn't happen, not from what I've known.
    Nov 16 2015
    DFW
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Tony said I get it cause of APR TCU tune... APR blames EPL ECU tune... Neither want to address issue. SMH
    I wonder what TCU tune he has????
    Jun 28 2016
    US
    I wonder if people running a GIAC TCU tune get it too when paired with an EPL ECU tune. If they don't, then you know where your problem is... APR.
    Nov 16 2015
    DFW
    Great question... Anyone have this combo?
    I still wonder what TCU tune he has since he is getting same soft code I am
    Aug 23 2015
    Texas
    I've done a few launches up to speed when testing the latest EPL Stage 1 93 octane file. I'm running EPL ECU and TCU tunes. After each run I did a full VCDS scan and I never got the engine overspeed fault. Now, there was a time in the past with older files where I got the fault, but I haven't seen it at all on the latest files.
    If I remember correctly, the fault in VCDS said something like, "maximum engine speed exceeded *warranty void*". Probably don't want to visit the dealer with that lingering.
    Nov 16 2015
    DFW
    Yep thats what it said
