Results 1 to 16 of 16
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Supercharged Badge Placement
    Hey guys, I am swapping out the V6T emblems for the OEM supercharged badges but I would like to place them exactly where they need to go. Would any of you fellow S4 owners please take some photos with a tape measure of the placement on the front fenders? TIA
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by 4Rings3Liters View Post
    Not necessary. They make an actual template for them. http://bd8ba3c866c8cbc330ab-7b26c6f3...eplacement.pdf
    If you still run into trouble PM me and ill take pics and measurements for you.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    2016 Porsche Cayenne Diesel
    Nor*Cal
    search is your buddy... found it...
    http://bd8ba3c866c8cbc330ab-7b26c6f3...placement2.pdf
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, EPL Stage 1, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, Ultra Racing Front Lower Brace, Ultra Racing Center Lower Brace, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Jul 04 2008
    York, PA
    Quote Originally Posted by DannyDeez View Post
    Quote Originally Posted by dluxxx View Post
    You guys are awesome, thank you! I must be using the search wrong because I tried it but I get so many results using every word I type in instead of all the words being used.
    Mar 21 2015
    Most of the time if you are looking for parts you can go to a few different websites for the parts and find useful info.
    Apr 05 2016
    Portland, OR
    I just swapped out my badges yesterday.
    Here is what I did:
    1. Park the car out in the sun to let the badges warm up. (Or use a heat gun if you have one)
    2. Remove the "V6T" badges using some string
    3. Remove excess gunk using rubbing alcohol and a micro fiber cloth
    4. Print and cut out the badge placement template linked above.
    5. Using painters tape line up the templates and tape them firmly in place.
    6. When placing the SC badges there is a little bit of play since the adhesive is tacky but, make sure you get it correctly placed!
    7. Remove the template and firmly push the SC badge
    Done?
    Agreed, ECS particularly has great write-ups!
    Geoff
    Established Member Two Rings ClarkGriswold's Avatar
    Jul 11 2007
    Las Vegas, NV
    Link to where you got them?
    2013 Audi S4 | GIAC Stg. 2 | CTS Turbo Intake | Fluidampr Crank Pulley 183mm | Revo Charge Cooler | Ice Silver Metallic | Prestige | MMI Navigation + | B&O | Sports Diff
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by ClarkGriswold View Post
    I tried a few pairs from Amazon and kept getting fakes.
    Ended up buying off an AZ member.
    You can also find them on ECS.
    Geoff
    Jul 04 2008
    York, PA
    I just forked up the extra money and got them from ECS to ensure they were the real deal. The dealership wanted $190 so this was a no brainer.
    https://www.ecstuning.com/Audi-B8_S4....0T/ES2954135/
    Jul 04 2008
    York, PA
    FYI... this seems like a waste of money however I have removed badges before using fishing line and other strings and this was by far the easiest.
    https://www.ecstuning.com/b-ecs-part...ool/bmwrrtool/
    Senior Member Two Rings JustPlaneChris's Avatar
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    Hah, that's hilarious. I used exactly the same product to remove my V6T badges, except I didn't buy it. You know what it is? A short piece of plastic banding strap from a shipping box.
    Chris
    2014 S4 - 6MT | Brilliant Black | Black Optic | Carbon inlays | Alcantara | B&O | CR-15 Strut Brace | 034 Intake Hose + K&N
    Established Member Two Rings douglasjboehme's Avatar
    Jul 22 2015
    1995 Land Rover D110 2.8TDi SW, 2016 Sepang Blue 6MT S4
    Blue Bell, PA
    Good luck getting these attached and please make sure you clean it properly before attaching. The dealer took 3 tries to get my Supercharged badges attached correctly on my ordered-new 2016 S4 6MT.
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    i put about 6 of them all over my car so people are aware of my supercharger :)
    Mar 21 2015
    Quote Originally Posted by douglasjboehme View Post
    There is no problem with them sticking when cleaned properly. That's sad they couldn't do it. This is probably the easiest thing you can put on the car.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    After removing the old emblems with a hair dryer and dental floss, I clean the residue off with mineral spirits. Then wipe down the area with rubbing alcohol. Badges will stick like gangbusters.
    Senior Member Three Rings hmc2261's Avatar
    Nov 25 2019
    Charlotte, NC
    Im having a heck of a time with the scale factor. Full scale is not correct. Any idea what it is?
