Results 1 to 33 of 33
    Jun 17 2016
    Chicago, IL
    APR Stage 1 Tune on B8 A4 - Is it worth it?
    Hey guys,
    I'm debating on purchasing the APR Stage 1 tune for my 2010 B8 A4. I'm at 80,220 miles as of yesterday. I don't have any check engine light on as of right now, and don't really have any issues. Are there any common issues or problems that I will be running into if I decide to go through with this? Will my average MPG be affected ? Obviously if I'm launching the car at every red light I understand it will be...but I mean if I continue with the same driving habits. Please help!
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by allang1374 View Post
    Hey guys,
    I would strongly advise asking Infiltrator first. He'll have a lot of great input about this post.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    well worth the money really wakens the car up I did not notice any drop in mileage based on how I drive, and highway mpg reported in the dash seem to be up about 1mpg on long trips even.
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Welcome to AZ.
    Answers:
    1.) Yes it is worth it.
    2.) There shouldn't be issues; APR has a large install base and the horror stories you occasionally hear about problems with tuned cars would likely have appeared anyway or with a different tune.
    3.) MPG will be the same if your driving habits stay the same, which they won't because the car will be way more fun post-tune.
    Friendly reminder that there's a wealth of information here, about this topic and many others, available by searching. If whatever you're looking for can't be found, we're happy to help.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    The main thing is to do maintenence before modifications. More power puts more stress on parts so if there are parts on there last leg when you add more power their more likely to break. Also not many people realize that lack of maintenance will create more power loss. So make sure the car is up to date before you begin your mods. Also the 2nd and equally important is supporting mods. Going faster isnt cool unless you can stop the car so mske sure to have a plan upgrade your brakes with at least some stainless brake lines and a better pad for better bite.
    Sent from my SM-G920T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Established Member Two Rings thrill23's Avatar
    Apr 30 2016
    OEM Parts
    Miami, FL
    Quote Originally Posted by Project Quattro View Post
    Welcome to AZ.
    Answers:
    Awesomeness
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by ToddBrunswick View Post
    First of all, does your car burn oil? As in do you have to add oil in between oil changes? If so how much? Checkout the thread on the first page for questions and answers.
    Second, I would just go Stage II, there's a lot of threads on this and you'll find out it's just worth the time, money and effort in doing so.
    Third, search through threads and if you find a thread on the topic you're interested in, ask on the already existing thread. If there is in fact zero threads on the topic you want to ask about, post a new thread.
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    STG 2!
    - iKe -
    2011 S5
    2011 A4 Avant
    Jun 17 2016
    Chicago, IL
    Thank you for your response. To answer your question:
    When I purchased the car at 56k I did have the engine rebuilt and turbo replaced by Audi under warranty because it failed the oil consumption test. The check engine light came on as soon as I drove it off the lot, luckily the warranty covered it. After that, I have not had any issues with oil consumption.
    Jun 17 2016
    Chicago, IL
    I was definitely thinking about this as well. I typically repair any issues right away, but I would like a heads up on what hardware I should upgrade before jumping right into this. Thanks!
    Sep 09 2010
    Destin, FL
    Search, you will find the answer on what mods to do for it in the million already existing threads!
    Hint: The APR site has what mods you need for the stage you want.
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by The Infiltrator View Post
    There he is! I was worried based on your first reply that you weren't feeling well today. Glad to have you back!
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Light em up, W!
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Hey guys,
    I'd recommend installing a HFC before you go stage 1 or 2. The car feels much more fun to drive once that's on there. If you find yourself needing more, then you're ready for stage 2. I personally went straight to stage 2 and skipped stage 1. I had the HFC and stage 2 tune done on the same day. It wasn't until I had to take my car into a dealer and needed to get flashed back to stock mode that I realized how much fun my car still was with just the HFC and no tune. Save yourself $600+ and just do HFC before you make the next choice is what I would recommend.
    At the moment, I still have stage 2 and I'm enjoying it, but I wished I would have just stuck with the HFC and no tune once I felt how great it still was.
    Also, I think APR may offer a 3 day free software trial which allows you to test the tune at no cost and then reverts back to stock.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    I was popping the popcorn... this was a major let down. In a good way
    HFC/ test pipe will make a decent difference in spool and power. I also HIGHLY recommend getting a bigger FMIC. Our cars are god damn furnaces and run way too hot even at stock boost levels. You will save yourself alot of headaches chasing hesitation, timing retard (pre-detonation) and constantly cooking your plugs. Some FMICS are a grand or more BUT you can get your hands on a Treadstone for $225 I believe With a few hose clamps and generic silicone hoses it works like a charm....and now that I mentioned plugs, get heat range 8 NGK platinum.
    ok no go search the rest. Welcome to the slipperiest of all slopes. This website has ruined the financial stability and weakened the marriages of many a man....enjoy
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by doowopaudi View Post
    But with out the stg 2 you'll have a check engine light!!! Can't really run a hfc with the special tune... spacers or special o2 sensors still don't work...
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by hyperunion View Post
    False, a spacer will eliminate the check engine light with a HFC in stock mode. I'm doing it now while I do the oil consumption on the car.
    Sep 03 2012
    Lehigh Valley, PA
    Everybody has had issues with running a hfc with a stock tune.. it happens.. maybe your an exception...
    It'll either happen now or down the road.. it will happen...
    Oct 26 2012
    St. Louis, MO
    I can run my spulen HFC with the tune on or off and rarely get a CEL. My tune files do not deactivate the O2 sensors. This does seem to be random by car and not predictable, based on varied experiences on AZ.
    Sep 09 2010
    Destin, FL
    The spacer is meant to stop the code while stock, the tune disables the rear O2 sensor. At least that's what I've read and my experience with it. I've never had an issue.
    Oct 26 2012
    St. Louis, MO
    My O2 sensors are active with the tune on, though, is what I am saying. I can pass inspection without going to the "stock" file.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by blbroo View Post
    Hmm, I was told APR disables the rear. Time to look it up. Now I'm interested.
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    I dare you to start a new thread.
    Oct 26 2012
    St. Louis, MO
    APR does, GIAC doesn't.
    Aug 10 2011
    North Whittier
    As far as I know, a HFC without a tune may trigger a CEL, but that should be no cause for concern since you know it's the HFC that's allowing more air to flow through. When my CEL went on, I've simply used a generic OBD2 scanner to check the error code, verify that it's the oxygen sensor and cleared it and went on my way until the HFC triggered the CEL again. I've driven about 3-400 miles in between with no CEL.
    Again, to answer the OPs question, I feel you should go with the HFC alone before jumping into stage 2 (or stage 1 without the HFC).
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    yeah if its an option hfc with a stage 2 tune is even better, it seems to pull smoother than the stage 1 tune did.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Established Member Two Rings Jg3's Avatar
    Jun 11 2015
    2005 A4 B6 3.0 cabriolet
    SGV
    It's worth it, big difference. I recommend you do the timing tensioner first going off my personal experience.
    Sent from my SM-G928V using Tapatalk
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    my story is a bit similar, bought car, it burned oil immediately, took back stage 1 then stage 2 consumption, ohh your cylinder walls are scored, so brand new crate engine goes in, at 65K miles, waited about a year, then I went stage 1, decent improvement, was a bit notchy in the midrange at times... did the 3.0TDI IC, waited another year , and then spulen HFC, and stage2, good increase, power feels smoother in delivery than with the stage 1. at 109K now
    id probably just recommend going straight to stage 2 if u do. but its nice to have more steps in performance, so your nto desiring more right away...
    Senior Member Two Rings acidvoodoo's Avatar
    Mar 11 2016
    Providence
    Interesting reply's, seems like 50/50 opinion on tune vs hfc. I'm at 36k and I've been thinking about getting APR stage 1 but I'm unsure as I don't want to void the remaining warranty. Does anyone know if installing a only a hfc would effect the warranty?
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by acidvoodoo View Post
    The HFC won't, the tune will with some dealers. You can flash it back to stock after having a tune but the dealer from there on will see that a tune was loaded before. Some dealers care, some don't. My dealer didn't care that I had it previously loaded so I have a good one but there are some that will just tag it TD1 right away.
    Sep 03 2012
    Lehigh Valley, PA
    Major emissions part removed and switched out to anything, especially now.... Audi would definitely reject if the need comes for a major warranty claim... Audi sends out service engineers to inspect cars requiring major warranty work before giving the dealership the okay....
    Aug 17 2015
    California
    Major warranty work would justify the ~$300 to remove the HFC and install the stock cat before taking it in.
    I'm not sure a HFC would void the warranty, it does not really modify the car, it is still a cat and provides the same function, albeit just a little more free flowing Ya I know, I'm probably wrong. But I bet some, or more than half dealers would not give you any problem with a HFC, hell would they even notice?
    I installed one a few months ago. Immediately felt the improved performance, lower RPM turbo spool etc, but now I feel like the ECU has adapted and I have lost any power gains, it feels like stock again. Is this possible? Could be just me getting used to the few extra HP. Perhaps my gas mileage got a bit better (less losses in the system). I cannot wait to go stage 2, but still have CPO for another 8 months. Marginal oil consumption (had stage 1 fix last November, and it is much better).
