    Veteran Member Four Rings gqambitions's Avatar
    May 27 2015
    Atlanta,GA
    first VAG scan...some questions
    A brief synopsis of the situation. My battery failed the "test" at an Audi dealership. I took it there to have a used car inspection done after I recently bought it. The car dealership I purchased it at replaced the battery and then this fault code comes up when I have a friend run a scan for me. what do these codes mean please? Upon looking at a couple of forum discussions hear I see it could be an issue with the a/c temp controls, or something along those lines. My a/c is very hot when I first turn it on but then it cools really well after a couple of minutes. Also noticed a loud sound when it is turned on from engine bay, nothing alarming, but it is just noticeable. I assume this is regular or maybe not. I came from a 2015 Acura TLX , so I understand that this is a 2010 Audi S5,and maybe some things I hear now than with my 2.4l Acura. For the battery coding I am thinking maybe they did not program it to the car? any advice would be helpful, thanks.
    Address 08: Auto HVAC (J255) Labels:Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1820 043 AQ
    Component: KLIMA 3 ZONEN H08 0171
    Revision: C1000000 Serial number:01211020091030
    Coding: 48122000
    Shop #: WSC 06325 000 00000
    VCID: 000FAA74939F223E7E-8054
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - ImplausibleSignal - Intermittent
    FreezeFrame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 103304 km
    Time Indication: 0
    Date: 2009.06.26
    Time: 00:14:38
    Address 01: Engine (J623-CAUB) Labels:079-907-560-CAU.clb
    Part No SW: 8T0 907 560 T HW: 8T0907 560
    Component: 4.2l V8/4V H12 0005
    Revision: 76H12---
    Coding: 01140009190F0120
    Shop #: WSC 49467 000 1048576
    VCID: 4B954D58EA593166DB-801E
    1 Fault Found:
    005634 - Power Supply Terminal 30
    P1602- 002 - Voltage too Low - Intermittent
    FreezeFrame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    FreezeFrame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    Readiness: 0000 0000
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    I would go to a measuring block and look at your battery voltage. Maybe try ensuring everything is tightened in the trunk? Cable loose, bad battery or bad alternator.
    If the battery is original, I'd say it the likely culprit.
    May 27 2015
    Atlanta,GA
    Quote Originally Posted by ColtS5 View Post
    ok, I will try that out. Dealership I bought it from will be taking a look at it as well. Thank you.
    Apr 10 2014
    Lambertville,Mi/Toledo,Oh
    Did you ever find the solution. I have the same problem!
    Junior Member Two Rings
    Aug 17 2018
    FL
    Quote Originally Posted by mooserahal View Post
    These cars can be buggy. Have you tried clearing the codes an seeing if they return?
