Results 1 to 17 of 17
    Apr 15 2014
    Ottawa/Gatineau Canada
    Will 4X Avant doors fit inside a Avant??
    I am wondering as I found a set of doors (4) from a Avant part out and.
    has anyone ever fit a full set of Avant doors inside a Avant?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Not gonna happen. One door fits, doubt you are going to get 2 or 3 . 4? No.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jun 08 2008
    Calgary AB Canada
    If you take the frames off I bet you could. Doubt you need the frames anyways?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Apr 15 2014
    Poop, I need the frames.
    Aug 03 2014
    WPB, FL
    Supposedly the only difference between sedan doors and avant doors is the window frames, so you could just take the frames since that is the unique part
    07 Q7 4.2 S-Line
    02 A4 B6 Avant - Sold
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    You should be able to fit all 4 doors INSIDE the avant as long as you can fold the rear seats down. Take some blankets or padding so you can stack them without damaging them.
    Jun 27 2011
    I bet you could fit 4 doors and 4 frames if you had a sawzall.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    ^Thats terrible advice.
    A plasma cutter would be best. Since it uses heat and doesnt cut away the metal. The heat will also help them reconnect when you take them out and put them back together. A sawzall cut would reduce the overall dimensions.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Veteran Member Three Rings g huns's Avatar
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    Roof rack? Got any kids? They make great ballast for loads thrown on roof racks.
    2012 A6 3.0 Premium Plus w/Sport Package
    Dec 17 2009
    Kentucky
    Quote Originally Posted by g huns View Post
    Heh loads...
    Apr 15 2014
    I made a post about the frames form a sedan and Avant being the same or different... I got 50/50 responses :(
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    the window frames are different, I have both and they are not the same, the wagon has a much flatter top, the sedan has a curve to it
    Apr 15 2014
    Phew...good thing the parts car is another Avant ;)
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    I'll bring my Eight to assist if the part out has a headlight up for grabs.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    I'm pretty sure the front doors are the same and interchangeable, but the roof line changes on the rear doors so that's where the frames are specific to sedans/avants. But I believe the question is if four doors would fit IN an avant as in trasporting spare parts. And I'd say no, not a chance.
    Aug 26 2005
    The official parts list shows that the Avant uses the same window frames as the sedan. I think all four doors will fit inside after removing the window frames and wrapping the doors in movers blankets. Maybe without removing the window frames also. You could try that first.
    Vorsprung durch Technik
    Apr 15 2014
    Quote Originally Posted by Gosser View Post
    Shoot me a email and I will give you the details...
    PM'd you my address.
