    Established Member Two Rings TylerG's Avatar
    Apr 03 2013
    United States
    Had 7 codes come up on a scan, wondering what you guys think?
    Address 01: Engine Labels: 06H-907-115-CAB.clb
    Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
    Component and/or Version: 2.0l R4/4V TF H16 0001
    Software Coding: 0104010A190F0160
    Work Shop Code: WSC 26131 444 100868
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F9B25EF865ACF639-802C
    7 Faults Found:
    4483 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    4629 - ECM Power Relay Load Circuit
    P068A 00 [032] - Opens Too Early
    Freeze Frame:
    5646 - Leak in Air Intake System
    P2279 00 [096] - -
    Freeze Frame:
    2838 - Fuel Rail/System Pressure
    P0087 00 [096] - Too Low
    Freeze Frame:
    5671 - Boost Pressure Regulation
    P0299 00 [104] - Control Range Not Reached
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 116325 km
    Date: 2016.06.21
    Time: 18:39:59
    4105 - Bank 1; System too Lean at Idle
    P2187 00 [096] - -
    Freeze Frame:
    4201 - Fuel Level too Low
    P1250 00 [096] - -
    Freeze Frame:
    2010 Ibis White Audi A4 B8 Quattro Premium+ S-Line w/ Nav
    Established Member Two Rings heatseeker23's Avatar
    Jan 04 2016
    B8 A4 Quattro | MK5 GLI | | GMT900 Silverado | MK2 TTS 15' (retired) | MK4 VR6 12V (retired) |
    Dallas/TX
    A few of those codes seem to come up when the PCV is messing up. It may be just the diaphragm of the PCV that needs replacing or the entire thing.
    Let others chime in but if it does turn out to be your PCV, i recommend just going ahead and buying the entire PCV. You can get it at a good price on rockauto.
    Apr 03 2013
    United States
    thanks for your input, really appreciate it. Anyone else have any ideas?
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Coming from a B7, seeing the P0087 makes me immediately think cam follower...highly unlikely in the B8 though. I'd check the boost/vacuum lines near and around the PCV, then the actual PCV itself. Like heatseeker said, a few of those codes point towards a PCV issue.
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Sep 30 2014
    Amhest/NY
    Check your air intake (filter, turbo outlet hoses, inter cooler hoses) looks like u have a boost leak
    The big hint is the boost pressure regulation, leak In air intake, and fuel rail pressure.
    I had similar codes when my turbo outlet hose popped off due to poor fitment of the crappy CTS turbo hose kit. I'm running EuroCode now
    If the amount of air is not right it would throw off the air fuel mixture. All codes were gone after fixing my boost leak
