Results 1 to 3 of 3
    Dec 19 2014
    Salt Lake City
    B7 S4 clutch replacement time! Recommendations? Other items?
    Hey all!
    At 112K miles and planning on the timing tensioner job (or engine swap), figure it's time for a clutch as well. It's orig as far as I can tell and no real issues other than age and the motor will be out. What are y'all's thoughts on what to replace (disc only? PP? FW?) and with what? I'm not planning on any real performance mods at this point so I don't need anything really heavy-duty.
    I'm figuring on also doing the snub mount, engine mounts too. Any particular gaskets to hit "as long as I'm down there"? This would probably be a good time to gut the down pipes and I'm going to try and slide an exhaust into the budget as well.
    Let me know what you folks think.
    Cheers!
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Replace everything it's an investment no need to go back in let's say 5k miles and replace something else. Just so everything and I suggest the upgraded JHM
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    for dd use rs4 clutch kit :)
