Results 1 to 6 of 6
    Nov 20 2007
    Phoenix, AZ
    A/C intermittently not blowing cold
    Hey everyone - Earlier this year my 2011 Audi A3 TDi S-Line started to blow warm air intermittently. Took it to the dealer, who said it only had 300 grams of refrigerant, whereas normally it has about 500g. So, he had the tech top off the freon.
    It is still blowing intermittently warm and also takes 8-10 minutes before cooling down in our 110 degree PHX summer heat. It used to start cooling down 2-3 minutes into my commute.
    Dealer says that the freon charge is still exactly where it should be; it's "just hot here right now", which is BS, because I had a new A5 loaner which froze my ass off last week.
    Any other thoughts on what the culprit could be besides low refrigerant? Thanks!
    Ahwatukian
    Phoenix, AZ
    Active Member Two Rings hangtime10's Avatar
    May 28 2016
    Whitby, Ont
    I had a similar issue with my previous car. Went to dealerships, Indys and AC experts. They wanted to overhaul the system. Turned out all I needed was to replace the relay. After that it was perfect. Worth a try and it's probably the cheapest thing to try.
    Oct 19 2013
    Saint James ny
    My 2015 was the n280 valve, common problem I was told
    Nov 20 2007
    Phoenix, AZ
    UPDATE: I finally got the dealership to replicate the issue of not cooling in very hot weather. Going to get the compressor replaced and the extended warranty will pay for the replacement!
    Apr 20 2021
    United States
    Quote Originally Posted by hangtime10 View Post
    where is the relay?
    Oct 09 2020
    Taylors SC
    How did you get the dealership to cover under the warranty?
