Results 1 to 3 of 3
Thread: Troubleshooting
    Jun 03 2016
    Tulsa Oklahoma
    Troubleshooting
    Hello, I'm in the process of repairing an A4. I'm having trouble with the Hood staying shut. I can get it to latch but at driving at a decent speed it'll pop up about an inch with the hook still latched. When pulling the Hood release I have a normal amount of resistance but it doesn't pop the Hood up. Also I'm getting the parking break malfunction + passenger airbag off error. It isn't giving any codes though.
    Any help would be appreciated.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    In regards to the hood, when you close it, pull on it to see if you can get it to pop open yourself. It's possible you might have to replace the latch mechanism and/or the cable to the latch. What's nice is there's a cable coupler, right behind the driver's side headlight, where only from that section to the hood latch needs to be replaced. You don't have to go all the way into the cabin; that's a separate cable.
    Do you have a VAGCOM? If so, cycle through the parking brake procedure.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jun 03 2016
    Tulsa Oklahoma
    I think I may have found the culprit. The bottom latch looks like there is a piece broken inside.
    Can anyone confirm if this is normal or not?
