Results 1 to 12 of 12
    Senior Member Two Rings Joey9's Avatar
    Mar 16 2015
    2009 Audi A4 Avant & Matching Trailer // 2009 Audi A4 Sedan APR Ko4, FBO, APR Stage 3+
    Rochester, MI
    Help! P0299 and P0140 Codes
    So I was on the highway going very fast, (around 130) and my check engine light came on. (Lets put all discussion about speeding and safety aside) I scanned the codes and got the current fault P0299 code - Turbo/Supercharger Underboost and the pending fault P0140 - O2 Sensor Circuit No Activity Detected Bank 1 Sensor 2. I've done my research about the P0299 code and people have been saying its my DV, waste gate, or a boost leak. Would going as fast as i was on the highway affect any of those components? My car (2009 A4 Avant) seems to be driving perfectly normal even with the CEL light on, so I'm wondering what could be causing the codes. I had the car checked out at Audi about 2 months ago and they did say my turbo bearing was failing, but I never had any other confirmation that their diagnosis was true. Any help would be appreciated, Thanks!
    Bagged B8.5 Swapped A4 Avant & Matching Trailer
    B8 A4 Sedan APR Ko4, FBO, APR Stage 3+
    Instagram // TiktTok // YouTube: @joeyjacobss
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Probably need a turbo. Did you ever get the wastegate arm recall done?
    Mar 16 2015
    Rochester, MI
    Quote Originally Posted by pierreb View Post
    the car is driving fine and i hit 136 and 130 again after the code came on along with 120 a couple times. since the car is driving fine with the code do you really think i would need a new turbo? and no i have not gotten the waste gate arm recall done
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by Joey9 View Post
    That P0299 will come and go under load, but won't change the fact that the wastegate isn't sealing properly. If your bearing is failing as well, I would suggest you change the turbo sooner rather than later. Depending on how many miles are on your car, you may be covered by that TSB, but I would call AoA to VIN verify before you remove your tune.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Mar 16 2015
    Rochester, MI
    the code disappeared this morning, am i fine? or should i still be worried? and so its something with my waste gate not sealing properly?
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Cars do not heal themselves.Better get it look at before it gets worst.
    Oct 23 2014
    _
    Quote Originally Posted by bakedziti View Post
    Fuck man.
    http://www.audizine.com/forum/showth...ranty-extended
    http://www.audizine.com/forum/showth...e-on-a-2009-A4
    http://www.audizine.com/forum/showth...r-Boost-P02990
    http://www.audizine.com/forum/showth...3-BP-gas-P0299
    http://www.audizine.com/forum/showth...an-anyone-help
    http://www.audizine.com/forum/showth...autionary-tale
    http://www.audizine.com/forum/showth...99-fault-codes
    http://www.audizine.com/forum/showth...hatter-flutter
    http://www.audizine.com/forum/showth...lapper-(P0299)
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Mar 16 2015
    Rochester, MI
    if I'm tuned will that void the extended turbo warranty? I can flash back to stock myself before i take it into the dealer if i need to
    Oct 23 2014
    _
    Yes.
    Warranty extension was 7years/70k miles or 8/80k (can't remember off the top of my head, but one of those links will tell you), but just call them before you go removing anything.
    If you have to change it at your cost, why not consider a K04 option? The swap for either isn't that bad if you can follow directions; check the DIY sticky.
    I'm really starting to think you're trolling people.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Sep 24 2013
    Chicago, IL
    Yes.
    i am also getting these codes and since i am at 105k the recall doesn't apply for me has anyone done a K04 direct swap without getting the full K04 kit?
    Mar 16 2015
    Rochester, MI
    Yes.
    i did my research on the codes, i thought my situation was different so i made a thread. my car doesnt have a td1 with audi so I'm just going to flash back to stock and see if that works. I talked to the dealer and they said my car is covered under the 7year/70k miles warranty just as long as i don't have any software on my car at the time. If i have to pay out of pocket I'm planning on going ko4.
    2020 A4 allroad
    NH
    Good luck. If you do decide on k04, don't forget you'll need to budget HFC and down pipe that match up.
