Results 1 to 7 of 7
    Mar 07 2014
    New Hampshire
    Deleted
    Deleted
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Nothing to prevent it really other than making sure the dsg is well maintained.
    Hopefully you bought a car that has had two services done on the dsg already (one at 35k and another at 75k miles). Typically the entire transmission does not fail unless you've been driving around on a failing mech unit for a while. Usually it's the circuit board that needs replacing (~1300 in parts and labor) but sometimes the mech unit itself needs to be replaced (~4500 in parts and labor).
    Welcome to the b8 s4 forum
    Dec 21 2013
    Get a good aftermarket warranty.
    Current: 2021 R8, 2019 A6, 2017 Ghibli SQ4
    Past: 2009 C300, 2011 C63, 2013 535i, 2014 S4, 2016 M4, 2016 Macan, 2017 Macan Turbo, 2017 E350, 2017 750i, 2018 Panamera Turbo
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    A Warranty might be useful depending on the price of it (vs the value of the car) and these cars can have rough idle at times so the rough idle is probably not related to anything DSG.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by Andrewmac View Post
    Is there anyway to tell if mechanical unit or circuit board needs replacing? Any dash lights or tell tail signs?
    It's mostly just luck. Keep up with fluid changes, but beyond that I don't worry about the DSG issues. Honestly even a completely failed mechatronics unit is barely worse than a clutch job on a 6MT car even if it does happen.
    Some common symptoms of a failing unit include a big clunk as it shifts into first. Another one is if you get a big clunk when shifting from park, or into park while stationary. Sometimes a warning message will appear too saying gearbox malfunction.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 27 2010
    Michigan
    Quote Originally Posted by LINDW4LL View Post
    Adding on, when you come to a stop it will lurch/buck forward before downshifting into 1st and coming to a stop. RPM surging in gear while cruising... If I remember anything else, I'll edit this post
    Oct 27 2010
    Michigan
    Saw your post. If you still need advice on how to proceed, shoot me a PM. Two courses of action to take
