Havent noticed it before, but before I was about to leave Virginia back to Chicago I noticed that my exhaust was smoking through the back. It was blue smoke noting oil burning. The engine was still relatively warm though not hot, so you can call it a cold start. I went for a quick drive with a little gas and after the 1mi drive the car no longer smoked significantly at idle, or really at all
Any idea on what could be causing this? I have a 800 mi trip ahead and dont want to be driving on a failing turbo if it turns out to be that. A great friend now and fellow az member has arranged a bit of shop time for me to figure out what is wrong. Has anyone else had this similar issue?
I was thinking, either valve stem seals, oil control rings, or turbo seals. The turbo area is clean on the outside no oil or anything and no engine oil leaks. Could it be a cracked valve cover or faulty pcv that is allowing oil into the intake? Again as far as the smoking goes I only noticed it smoking significantly at cold start but as soon as i drove the car a bit it stopped smoking at idle. Thanks to all.
Sent from my SM-G920P using Tapatalk
