Results 1 to 14 of 14
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    Lowering spring instal DIY?
    Can anyone send me a link to a DIY for installing lowering springs? I can't seem to find one.
    Sorry if this has been asked before but I've tried searching and came up empty :/
    Thanks
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Mar 11 2012
    Audi A5
    Ventura, CA
    These are for coilovers but essentially the same thing. Just putthe stock struts back in after changing the springs instead of replacing them with the coilovers.
    VW Vortex
    http://forums.vwvortex.com/showthread.php?4331031
    ECS Tuning
    http://bd8ba3c866c8cbc330ab-7b26c6f3...llation_r1.pdf
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Established Member Two Rings Anthony1491's Avatar
    May 15 2015
    Toronto, Ontario
    Quote Originally Posted by Sauci View Post
    VW Vortex
    ECS Tuning
    ECS tuning guide was crap for my install, use the vortex one
    2011 Audi A4 Deep Sea Blue
    GFB DV+ - RS4 Grill - ECS Silicone Inlet Hose - Tint - AFe Filter - Ultra Racing Strut Bar - Eurocode HFC - Intercooler Soundbox Delete
    Steering Wheel Paddle Shifter Retrofit - Rohana RC22 19" 9.5 et45 - S4 Struts & Sway bars - Rev Motoring Springs - Custom Magnaflow Exhaust
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I would personally do it the right way and go coilovers.
    Sep 09 2010
    Destin, FL
    VW Vortex
    ECS Tuning
    First off, do not use your stock shocks. Do it the right way and get new shocks meant for the drop otherwise your stock shocks will give out after a short period of time. Plus the ride won't be as good.
    - - - Updated - - -
    Quote Originally Posted by ducati View Post
    Right way? You mean your preference?! Springs are great and I've had a great experience with them!
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / B7 S4 Avant 6MT / Subaru Outback Limited
    The links Sauci provided are the same two my buddy and I used to remove the stock suspension and install the Bilstein B12 Kit this weekend - everything you need to know will be in those two threads. Rear is a PITA as you need to lower the subframe in order to get the spring out.
    As Infiltrator said...do both shocks and springs at the same time - your stock shocks won't last and you will be back in there in less than a year.
    FWIW - very pleased with the Bilstein B12 Kit - perfect drop and didn't really sacrifice ride quality.
    May 24 2007
    PA
    Quote Originally Posted by CONative View Post
    did you replace the hardware bolts during the swap?
    May 15 2015
    Toronto, Ontario
    Quote Originally Posted by s4baby View Post
    Many of the bolts are torque to yield bolts which are required to replace however the general consensus that I got from researching on a couple different forums is that they are ok to reuse. I ended up using the same bolts
    May 16 2015
    VW Vortex
    ECS Tuning
    Thanks man I appreciate it!
    AKA: NathanMansoor
    May 16 2015
    Quote Originally Posted by The Infiltrator View Post
    - - - Updated - - -
    Will do thanks for the advise
    AKA: NathanMansoor
    Mar 11 2012
    Audi A5
    Ventura, CA
    I was able to do the rear without dropping the subframe. If you have the type of spring compressor that goes on the outside of the spring, rather than the middle it's possible to just barely get them in there
    May 06 2015
    Honestly no. I called my local shop to get their two cents - although it's recommended they always give the customer the option (at their expense). It's not going to keep my up at night knowing how much work it was to remove and reinstall to torque spec
    Cheers,
    Ry-man
    May 06 2015
    So I have the compressors that go on the outside as well but we struggled with the tight space to work. I picked up these:
    https://www.amazon.com/gp/aw/d/B00SX...GnL&ref=plSrch
    Worked great for the fronts. But the rear was a PITA. Once we dropped the subframe we were able to fit the compressor on and spring was out < 1 minute.
    Cheers,
    Ry-man
    Mar 11 2012
    Audi A5
    Ventura, CA
    I had to do each facing a different direction and stick the wrench through the spring to get it started lol. But I also have a 5 so there might be more room down there
