Results 1 to 15 of 15
    Feb 12 2008
    Michigan
    avant owners, where does this go?
    had the back of my avant apart all winter and just put it back together, but I can't figure out where this piece goes. Ive googled the part number but still can't find where it belongs
    Theres clips on one side and foam on the other.
    part number 8E9 864 897 A
    Saint Cloud, Fl
    In theach cubby hole on the left right side of the trunk
    instagram ------------> low_enforcement
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    That is not the cover for the right or left cubbies. At least it does not look like either one on my Avant. Part description is "Blind for boot lining trunk lining luggage compartment cover for lock carrier net partition" 35
    Is it the bottom/tray portion inside the passenger cubby? Sorry, I'm not near the car to compare.
    Feb 12 2008
    Michigan
    I just see nowhere in that area that it would go, in the picture it looks like it lays flat, but it has nowhere to fit.
    I don't know why I waited so long to put it back together.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    If I can get back to my shop here soon I'll take a look. Does your car have the Bose system in it?
    Feb 12 2008
    Michigan
    Bose, yes
    Jan 01 2012
    2004 A4 Avant
    CO
    that piece goes in the left side cubby, underneath were the antenna connections are. if no one can post a picture, ill get one for you later today when im off work
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Jan 31 2015
    Boise Id
    It must go underneath the side panel itself because my cubby is molded into the side panel.
    Feb 12 2008
    Michigan
    Makes sense, thank you!
    Feb 12 2008
    Michigan
    after a lot of pondering and puzzling around, I found its home, yes driver side, below the cubby hole, foam facing down. The diagrams must show for right hand drive cars? There's nothing under sub housing/amp.
    Thanks for the help
    Jan 01 2012
    2004 A4 Avant
    CO
    Glad you got it figured out! Worked late and completely forgot about this, sorry.
    Feb 12 2008
    Michigan
    Darn, still have extra pieces, two trapezoid shaped pieces, ETKA says trim support but can't tell where
    Part number for both is 8E9861669
    Link to ECS photo
    https://www.ecstuning.com/b-genuine-...ort/8e9861669/
    Jan 31 2015
    Boise Id
    Those go on the back trim panel at the rear of the spare tire well. They help support the cargo floor.
    Jan 31 2015
    Boise Id
    #22 in your pic you posted.
    Feb 12 2008
    Michigan
    Thank you
