Ok... I'm about to give up on this thing and send it to a shop. Here's where I'm at right now.
Brand new FX400 and TTV flywheel.
Brand new slave and master. Both have now been replaced twice.
Brand new USP slave line.
Clutch has been bled a million times. You can drive the car and it holds 400ft-lbs but if you push the clutch more than like an inch the pedal will stick to the floor. It's like there's not enough pressure to push the pedal back up. If I remove the clutch pedal spring the pedal returns on it's own. With the spring in it requires quite a bit of force to pull the pedal off the floor.
The only thing I can think of now is that I put the clutch spring back in wrong or something in the bell housing is messed up. Can someone please throw some ideas out to me? Something I may be missing?
Does anyone have a pic of the spring orientation? To me, it seems like it can only really go one way... but maybe I'm wrong. Is the spring there to return the clutch back up or to make it easier to depress the clutch?
