Results 1 to 6 of 6
    May 17 2012
    Houston, TX
    Help understanding VAGCOM fault codes / resetting codes
    Need some help. I had a BBK installed and now have the brake warning due to unplugged pad sensors. I searched but didnt find what others did for this, but thought i could just delete the fault code. Not sure why there is a fault for parking brake though - or is that what is triggered by have the pad sensors unplugged.
    Never did this before so thought i'd do the autoscan first (per Ross Tech recommendations) and I got a few faults, which was scary at first. I also had solid engine mounts installed as well - i am assuming this is what the engine fault is for. I had the left fog light go out, which is just replaced before doing the scan. I guess it didnt reset itself and i have to delete the fault?
    Then there are others that i am not sure if i sure be concerned about of not. No issues with car performance, but i am also breaking in a new clutch so cant really drive the car hard to notice if there are performance issues at the top end.
    Below is a copy of the auto-scan file. Can someone take a look and let me know if i simply just erase all the faults and be on my way, or do i need to do anything else? I really want to get rid of the brake warning because its there all the time. Any help would be appreciated. Thanks
    Sunday,26,June,2016,13:52:28:47860
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    www.Ross-Tech.com
    VIN: XXXXXXX License Plate:
    Chassis Type: FL (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 22 36 3C 42 46 47 52 53 55 56
    5F 62 6C 72
    VIN: XXXXXXXX Mileage: 62210km-38655miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 1010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
    Component: 3.0T SIMOS84 X08 0003
    Revision: --X08---
    Coding: 0104000A180F0128
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
    ROD: EV_ECM30TFS0218K0907551D.rod
    VCID: 326BF065659595AEB8-8066
    1 Fault Found:
    6003 - Left Engine Mount Solenoid Valve (N144)
    P1571 00 [109] - Short to Plus
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 15
    Mileage: 60480 km
    Date: 2010.01.23
    Time: 17:19:51
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 280D1A
    VCID: 020B60A59DB5E52E68-8056
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 181
    Mileage: 60868 km
    Time Indication: 0
    Date: 2010.01.29
    Time: 15:30:56
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0280
    Hex Value: 0x0032
    Hex Value: 0x0998
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 0F0100
    Shop #: WSC 06325 000 00000
    VCID: 77FD0171C677B0864F-8022
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 174
    Mileage: 60350 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:00:00
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0180
    Revision: C1000000 Serial number: 01241120111109
    Coding: 66102000
    VCID: 000F6AAD93B9F73E7E-8054
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 174
    Mileage: 60350 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:37:18
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000001148182
    Coding: 260010110034AF212600080300003D0D0F9C92480201016100 0000
    VCID: 3C77DE5DBFD153DE62-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 251111 H07 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
    Component: HOMELINK H01 0010
    2 Faults Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 195
    Mileage: 59918 km
    Time Indication: 0
    Date: 2016.05.05
    Time: 16:25:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 161
    Mileage: 55335 km
    Time Indication: 0
    Date: 2015.10.18
    Time: 07:50:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0081
    Revision: 11001001 Serial number: 36861132606532
    Coding: 20000D
    VCID: 4A9B8885E505FD6EE0-801E
    No fault code found.
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003GLD90073T
    Coding: 303837354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4581BBB9C41B12160D-8010
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R1100006XJP
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME4A05273FJ
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344MSME66617814D
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME4F64004AK
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME3465585ES
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME4C643A7AC
    Crash sensor for front airbag; front passenger side:
    Serial number: 63832SME0564157A
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
    Component: Lenks.Modul H17 0014
    Revision: -------- Serial number: 90372KKB000OK
    Coding: 000016
    VCID: 3E73D455A9CD41CE4C-806A
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
    Component: KOMBIINSTR. H12 0258
    Revision: 00000000 Serial number: EJG56HMCC
    Coding: 8B1509008B00D705020000
    VCID: 4189AFA9D8333E3631-8014
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AJ HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0120
    Revision: FC201059 Serial number: 5900F11B14011B
    Coding: 00C303
    VCID: 09197789A083B67629-805C
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8040
    3 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 100
    Reset counter: 194
    Mileage: 52015 km
    Time Indication: 0
    Date: 2015.07.17
    Time: 15:18:00
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 135
    Reset counter: 194
    Mileage: 52015 km
    Time Indication: 0
    Date: 2015.07.17
    Time: 19:18:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.20 V
    Count: 17
    00457 - Control Module for Network (J519)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 174
    Mileage: 60350 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:00:01
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 11.60 V
    Count: 7
    Bin. Bits: 10000
    Time: 0.90 s
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
    Component: 4 Wheel Drive H13 0025
    Serial number: 000911110001044
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 2E53E41571ADB14EDC-807A
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0076
    Revision: AA000000 Serial number: 00000019114281
    Coding: 00581B00000000000000
    VCID: 3B75DD41BADF54E66B-806E
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0030
    Revision: 00H01000 Serial number: 6PZ 009 014-82
    Coding: 0000001
    VCID: 3C77DE5D7FD153DE62-8068
    Subsystem 1 - Part No: 8K0 907 568 H
    Component: J0770_SWA_Slave_H01 0030
    Subsystem 2 - Serial number: 6PZ 009 014-92
    Subsystem 3 - Serial number: 5F17.11.1100H010003C324941ÿ
    Subsystem 4 - Serial number: 324941ÿ
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1501
    Coding: 011C13204E00410001
    VCID: 53A595E1324FBCA693-8006
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0163480010
    Coding: 0106063A00FA444580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0070
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 174
    Mileage: 60350 km
    Time Indication: 0
    Date: 2010.01.22
    Time: 00:00:00
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
    Component: DSP Prem H10 0190
    Revision: 00010001 Serial number: 34804011890103
    VCID: 7AFB1845F565ADEE30-802E
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    VCID: 52AB90E50D55B5AE98-8006
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 20000000157162
    Shop #: WSC 00000 000 00000
    VCID: 3467F67D97819B9EAA-8060
    2 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 141
    Mileage: 60868 km
    Time Indication: 0
    Date: 2010.01.29
    Time: 15:30:56
    Freeze Frame:
    Voltage: 12.20 V
    Count: 38
    Speed: 0.0 km/h
    Hex Value: 0x0160
    Hex Value: 0x0002
    Hex Value: 0x0101
    02442 - Function Lamp in Control Head
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 141
    Mileage: 60868 km
    Time Indication: 0
    Date: 2010.01.29
    Time: 15:30:56
    Freeze Frame:
    Voltage: 12.20 V
    Count: 72
    Speed: 0.0 km/h
    Hex Value: 0x0170
    Hex Value: 0x0008
    Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
    Component: AFS 1 H01 0040
    Revision: 00H01001 Serial number:
    Coding: 0000019
    VCID: 326BF065AD9595AEB8-8066
    Subsystem 1 - Part No: 8K0 941 329
    Component: AFS-Modul links H01 S001
    Subsystem 2 - Part No: 8K0 941 329
    Component: AFS-Modul rechtsH01 S001
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 B HW: 4G0 035 082
    Component: Radio U SIRIU H53 0076
    Revision: AB001007 Serial number: 156KB0B7578458
    Coding: 020007010000000001
    VCID: 1F4D09D10E0728C667-804A
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
    Component: H-BN-NA H52 0165
    Revision: -------- Serial number: 490K80B7652975
    Coding: 010200000206A1EF55000F0E000000030000
    VCID: 3979C749B0E366F679-806C
    Subsystem 1 - Part No: 8R0 060 884 AD
    Component: NAR 2011 0505
    Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Component: DU7 High H41 0104
    Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
    Component: E0380 Bedient H08 0100
    Subsystem 4 - Part No: 8R0 060 961 A
    Component: CD-Database 2712
    2 Faults Found:
    00658 - Control Head
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 181
    Mileage: 60868 km
    Time Indication: 0
    Date: 2010.01.29
    Time: 15:31:51
    Freeze Frame:
    Voltage: 12.40 V
    02244 - Button in Control Head is Stuck
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 60868 km
    Time Indication: 0
    Date: 2010.01.29
    Time: 15:37:27
    Freeze Frame:
    Voltage: 12.30 V
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000001
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1501
    Coding: 010C13204000210001
    VCID: 56A36CF521BDA98E74-8002
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H05--- Serial number: 525PA8-J1890ET
    Coding: 1000006
    VCID: 387FC24D4BE97FFE86-806C
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1501
    End-------------------------(Elapsed Time: 03:29)--------------------------
    Mar 21 2015
    Needs a new battery I believe. How old is your battery, might want to get it checked at Autozone.
    I think you need to short the wear sensor for the break pad fault.
    May 17 2012
    Houston, TX
    My battery meter shows full in the car info but I'll def get it checked out.
    Would it be safe to erase all codes and see which ones come back? I'm curious about others' experience erasing all codes and how they did it - individually or from the main windows where you can delete all. This stuff scares the heck out of me because I HATE the dealers and don't want to create a reason to go there.
    Mar 21 2015
    Looking again some of those are old. I would erase them and start fresh. Most likely your recent ones will come back. Usually when you start getting a bunch of random codes like this it's the battery but do to your old ones who knows. I doubt the old ones will come back, they don't repeat.
    May 17 2012
    Houston, TX
    Thanks. The dates are wierd because it says 2010 but I bought the car in 2012. Is a '12. Will def try to delete all and see what happens.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    You need to attach the wear like you going to use it and zip tie it out of the way or cut the sensor and twist the wires together to keep the loop closed. Clear your codes, see what comes back and go from there.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
