Results 1 to 4 of 4
    Oct 19 2008
    Brooklyn
    Grinds going into 1st and 2nd
    I bought the car not running so i dont know the co dition of the trans before hand. At first I could only get Into 5th so I re bled the clutch because I had to replace the slave clynder anyway. Adjusted the shifter and found the trans mount collapsed so I stuffed something in there temporarily. Now I can get I into all the gears but 1st and second grind bad. Any ideas?
    Sent from my SM-N920V using Tapatalk
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    can you get it in gear with the car turned off ?
    Junior Member One Ring
    Jul 10 2015
    Alamogordo, NM
    I had the same problem with third. I had to replace the clutch and flywheel.
    Oct 19 2008
    Brooklyn
    It does go into gear with the car off. It's not a new clutch but it looks good when I pulled the motor
