Results 1 to 9 of 9
    Feb 23 2015
    Middle GA
    Need help with A/C
    Hey guys- I'm hoping for some help in diagnosing my A/C problem.
    Symptom: It doesnt blow cold.
    Here is what I have checked:
    Compressor does not turn on when on max A/C.
    Low side shows overpressurized, but that may be due to compressor not being on.
    Ran VCDS. No Codes, other than recirc flapper.
    Ran VCDS test. it DOES make the compressor turn on, but then shows an error. No real help, other than proving that there is power to the comp.
    Replaced the pressure switch with one from the junkyard- did not help.
    Replaced the 267 relay with one from junkyard- did not help.
    SO: I do have power to the compressor, and its not low on refrigerant. Should I try to bleed some refrigerant from the system to bring it into the "green" range? Also, why would the low side pressure be too high? I've never charged the car.
    Any advice/help would be appreciated.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Yes if you changed the clutch relay and the compressor itself, id recommend recovering the excess refrigerant if you have a recovery machine and tank. if not, purge a little till you are in the specified PT zone for 134a at the ambient temp. i would also check the high side sensor mounted on the condensor and the orifice tube located in the high pressure pipe.
    Feb 23 2015
    Middle GA
    a4kamila6, thanks for the response. I let refrigerant out until I was in the green zone. Still no dice.
    I have done some more troubleshooting:
    I tested the 267 relay and it functions as normal.
    I found that the (+) wire that was leading to the compressor was damaged, so I spliced in a new wire.
    The low side now shows normal pressure.
    The compressor comes on when connected directly to (+).
    After testing the relay, checking low side pressure, and swapping the high pressure sensor with a replacement, what is there left to do?
    Sep 30 2015
    You have to check the high side pressure also because if one side is abnormal, it can help you determine if you have a leak, a restriction or etc. I doubt you have a leaky evaporator. At this point its just a process of elimination. You verified compressor wire is fixed, relay and sensors work, freon charge is good... Maybe check the orifice tube located in the high side pressure pipe. to my understanding, this tube is a passive throttling device that flashes our freon into around 25% vapor and 75% liquid mixture, as the freon passes through the evaporator, it attracts the heat from the cabin and basically on the way back to the drier and compressor, the freon gets superheated and flashes back into a vapor mixture which then gets compressed again and yada yada, goes through condensor and subcooling process. also make sure you have the correct amount of PAG compressor oil inside the compressor.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Does the 40 amp condenser fan fuse affect the compressor? The one under the drivers bolster?
    Sep 30 2015
    Quote Originally Posted by Avant Nate View Post
    I think that fuse is only for the aux/compressor fan but worth a check. I wonder if OP's compressor clutch works fine.
    Feb 23 2015
    Middle GA
    Update: the compressor will run when directly connected to power. I ran it for 5minutes last night, and unfortunately, no air came out cold.
    Last week, I tested the aux fan and found out it was dead. It's now replaced, and didn't make any difference.
    What's next to check? What does the control unit check to be functioning before turning the compressor on?
    Also, while running last night, I checked the low side gage. Is it normal to do this?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    You are way under charged
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    I would evac and recharge. There's no way to tell how much refrigerant is currently in the system.
    You mentioned there was an error from vcds when testing the compressor, what exactly did it say?
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
