Results 1 to 40 of 5210
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Bell Performance - Ethanol Defense. So I bought some of that...put about 1.2 oz to 12 gals of gas @ E32. Their website mentions 1oz to treat 10gals and also mentions importance of treating E10-15 gas.
    So are you guys just going with the 1oz to 10g or are you compensating for the higher E you run?
    Did you notice any hesitation or minimal loss of power? Only ran the car once since adding it...could've been weather cond's or imagination.
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Mar 20 2017
    Algonquin IL
    Quote Originally Posted by vpls4 View Post
    I haven't used fuel additives since my first car...I never saw a single one that provided any benefit. Can't speak for others on here, but my guess is that most are just buying premium grade fuels (Shell, etc) and if are adding, it's only race fuel. I haven't seen any downside to running an ethanol mix other than needing to fill up a bit faster, using two pump nozzles, and now hitting the limits of my fuel pump with a 194pulley and cooler weather. (HPFP will hopefully correct).
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I've been running Lucas ethanol condioner and now Starbrite. Never seen or felt any downsides. My lpfp was getting clogged recently from running full e85 and was bogging during acceleration. I added 1.5 oz of Starbrite and I was able to run a full tank without bogging, pretty amazing. I want to try Bell, I heard it doesn't use alcohol which is good for the long run.
