Originally Posted by
friskuh
Loe, or whoever knows; what’s the limiting factor for high power in our engines? Loe said the rods tap out at around 700 wtq but isn’t the block itself very weak. for example, i’ve been thinking about adding a forged 3.2 crankshaft & adding forged 2.7t rods (they will fit with the 3.2 crankshaft) but would it just be useless since i’ve heard the block itself is weak & needs an iron sleeve for the pistons? sorry if what i’m saying sounds confusing, i can clarify if i lost y’all.
Not sure, but we are about 250awtq away from throwing OE rods at this point with a DP/UC/Ported set-up. I will miss this platform when I go (I've started searching slowly these past two weeks, summer isn't exactly the best time to get the best deal unfortunately), this engine/Gen II DSG is a gem and so is this platforms reliability, can you imagine what this car would do with a 300-400lbs weight reduction without changing what we current have in mod? I hope you all continue to see where the limitations are, it's definitely time to move onto "stage III-IV" levels of power on this car. Single-Turbo kits have been craved for a bit recently and I hope one of the major tuners will listen and develop something unreal.
Do you plan on utilizing the 2.7t OE rods or aftermarket ones? I believe our rods are stronger than theirs.
