Page 2 of 131 FirstFirst 12341252102 ... LastLast
Results 41 to 80 of 5210
  1. #41
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Quote Originally Posted by AudBoost View Post
    I debated whether or not to go with a damped pulley or a solid pulley and I read the below thread a more than a few times. The debate starts on page 2 post #77.
    http://www.audizine.com/forum/showth...-failure/page2
    Torquewrench brings up a lot of valid arguments for a dampened pulley and then towards the end S4Leistung brings valid arguments against it. I guess we won't know the extent of either pulley until people get more miles on them. I do have a friend that had the JHM solid pulley on 2012 for over 20k and the car ran great. He sold his 2012 for a 2014 and moved the JHM crank pulley and 10K+ miles later and says he has no issues.
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
  2. #42
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by whiped View Post
    Interesting, he said 186 in his selling thread a few minutes ago.
    Can anyone with the GMG 180mm confirm it needs some grinding?
    I have the GMG pulley installed (with AWE sc pulley) and grinding was not required.
  3. #43
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by ntsantos View Post
    Thank you. I assume you are running the GIAC beta tune?
    Any numbers for us?
    Geoff
  4. #44
    Dec 06 2015
    San Ramon, CA
    Any numbers for us?
    Running EPL dual pulley e85 tune. I had GIAC, but wanted to run e85 and epl was or is the only one with a full e85 file. No numbers yet...
  5. #45
    Apr 05 2016
    Portland, OR
    How do the EPL and GIAC tunes compare? (Obviously subjective but, I'm curious)
    Geoff
  6. #46
    Jun 17 2010
    Madison WI
    I've updated the chart. Here is a new screenshot for you Loe.
    Thank you, this is great! Makes me want to go with just a 203 crank pulley instead of installing my CTS pulley.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
  7. #47
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by BillyG View Post
    I updated the spreadsheet again since 184mm pulleys need the modification as well.
    FWIW, this is all that needs to be shaved down:
    Geoff
  8. #48
    Dec 06 2015
    San Ramon, CA
    Kinda apples and oranges since giac wasn't e85. Definitely loving the epl tune.
  9. #49
    Apr 05 2016
    Portland, OR
    Fair enough, I'm mostly thirsty for numbers as EPL doesn't have much out in that department especially for higher ratio tunes.
    Geoff
  10. #50
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Anyone here have experience with fluidampr? I've heard good things overall about them on other applications. I would probably get the 189mm adapter since thats the most aggressive size they make to go with a smaller sc pulley
    Sent from my SM-G925V using Audizine mobile app
  11. #51
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    I'm jumping to 206 once I get my Coldfront kit put in and figure out my living situation. (Might be moving)
    Does the 183 mm fluidampr need any clearancing?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
  12. #52
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by ModItNow View Post
    Fluidampr is well known across many platforms but, I don't think many here have it yet. Also, 189 is not the most aggressive. A few here are running 194 with a smaller SC giving pulley ratios of about 3.4. (See the table for reference)
    We don't yet know what will happen as the supercharger passes 24k RPMs so at this point it is all trail blazing.
    Quote Originally Posted by rtl5009 View Post
    I am not positive but the picture above is from a 184 mm pulley so I would like say yes. Even if you didn't have to trim it down I probably would anyway just to be safe
    Geoff
  13. #53
    Jul 28 2009
    Philadelphia PA
    179 is good with zero trimming correct? Both pulleys are ribbed. It walks that far over?
    c8 a6 allroad
  14. #54
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    Correct.
  15. #55
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Oh I was just saying with the fluidampr the most aggressive they make is 189 (to go with a 57mm pulley) 194 sounds good to me! Yeah sounds like its definitely at your own risk at this point. Thanks
    Sent from my SM-G925V using Tapatalk
  16. #56
    Senior Member Three Rings madman4you's Avatar
    Oct 13 2009
    07 GSX-R 750
    Ontario
    No grinding required.
    2012 S4 - Phantom Black w/ a bunch of good stuff done to it
    Best 1/4 =[email protected] Until next year...
  17. #57
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Thank you whiped, front page has been updated.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
  18. #58
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    Is this picture taken from the bottom of the engine facing up?
    Is that the crank pulley on the right (above the DAYCO lettering)?
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
  19. #59
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by Quidproquo View Post
    Yes it is taken from the bottom up. In the illustration below the area between 1 and 4 is where the piece that needs to be trimmed is located.
    2016 S6
  20. #60
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    The DAYCO belt is on the crank pulley and passes by the tensioner in this picture. This was taken on the KI 194 mm pulley. You can avoid grinding by using a 6 rib belt, vice the factory style 7-rib belt. That DAYCO belt in the picture started squealing and I replaced it with a 6-rib belt (all I could find locally in a pinch), there is more clearance with the belt hung on the forward rib.
  21. #61
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by Jflow23 View Post
    Just to clarify, with a 6 rib belt, no grinding is necessary? Thats great news if you can clarify.
    FWIW, domestic guys run into belt size issues as well when running higher pulley ratio's and have to also purchase belts with less ribs (8 rib versus 6 rib on certain combinations), no reported belt failures that I could search for dating waaaaay back to at least 2003 on the SVT Mustang Cobra "terminator" when going to a reduced size.
  22. #62
    Feb 01 2015
    Lancaster, PA
    Anyone have a resource for belt LENGTH? This is my first time messing around with any differently sized pulley's. I always built my cars for DD so I kept all my accessories running strong and always ran turbos so there was never a need. I'm have the 189 FD pulley coming next week and want to ensure I have the right belt for my combo. Is there a formula or general approach to belt sizing?
  23. #63
    Apr 09 2007
    Beaverton OR
    Quote Originally Posted by Loe View Post
    That picture is from my install. Based on the amount of interference I had, I am confident that a 6-rib belt will not require grinding. I'll crawl under there this weekend to get you guys a pic with the 6-rib belt installed.
  24. #64
    Apr 09 2007
    Beaverton OR
    Used an endoscopic camera...please excuse the quality
    Bottom line, I'm convinced that 6 ribs will not require grinding.
  25. #65
    Aug 09 2015
    Sarasota, FL
    that is awesome! I"ll make sure to get some pictures of my install as well as soon as my larger OD pulley arrives
  26. #66
    Feb 25 2014
    Texas
    Currently running an APR blower pulley with a JHM overdrive crank....would it make a noticeable difference if I swapped the APR pulley for a CTS given the size difference? Worth it?
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
  27. #67
    Jun 28 2016
    US
    Maybe so, but remember that you're losing surface area on both the crank and supercharger pulleys for belt traction, so there's a slightly greater chance for slippage. How much and if any is unknown, but just wanted to put that out there since the chance increases with less surface area with one less rib.
  28. #68
    Jun 28 2016
    US
    Quote Originally Posted by AudiS4B8 View Post
    According to the charts, like 300-350RPMs on the blower more at 7k if you do it. How much that'll get you compared to the labor to change out the pulley is unknown and a call you'd have to make.
  29. #69
    Apr 09 2007
    Beaverton OR
    Quote Originally Posted by SwankP3RF3ct10n View Post
    True, but the 7-rib was slipping...6-rib is ultra quiet. No issues up to 6800 rpm. The pulley came with 53" belt, but the tension is slightly off. I found a replacement in 6 ribs that is made of a different material and is thicker and stiffer...tension is much better.
    I'll likely switch to 6-rib 52.5" belt at the next oil change. I have been unable to find 7-ribs at 52.5"
    I don't think the additional rib will make a significant difference, especially with consistent inspection.
  30. #70
    Apr 05 2016
    Portland, OR
    I would put a bigger crank pulley on instead of swapping out the SC pulley.
    Looking at the chart (Specifically Ratios)
    Switching to the CTS pulley will net you a +0.039 gain in ratio which as Swank pointed out yields ~280 RPMs at WOT.
    Stepping up to say a 189mm crank gives you a +0.173 ratio gain yielding an extra ~1245 RPMs at WOT
    Ultimately the choice is yours, CTS pulley ~$160 + install, KI 189mm pulley ~$460 + install, or grab the KI 186mm in classified right now for $430, Fluidampr also has an offering which would be a few hundred more
    Geoff
  31. #71
    Apr 09 2007
    Beaverton OR
    No special tools required for crank install either. It wasn't too difficult to do myself.
    It looked easier than the SC pulley IMHO. Can't actually comment on the SC pulley install...went straight to 194mm KI.
  32. #72
    Apr 05 2016
    Portland, OR
    That was my thought as well. Granted the SC is more accessible but, you still need to heat/chill the pulleys to do the swap.
    Geoff
  33. #73
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Are you waiting till it's cool down there to put it on or just going for it now? 194 KI with the giac pulley right?
  34. #74
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by mrmomo313 View Post
    If I had to take a guess he is putting it on now.
    I know Matty sent it not that long ago and that Matty is currently running stock cooling on his rig.
    Loe has the AWE SC pulley as noted in the 1/4 mi thread: http://www.audizine.com/forum/showth...your-time-here
    Geoff
  35. #75
    Apr 09 2007
    Beaverton OR
    **OFFICIAL** Life Beyond Stage II: the higher pulley ratio development thread
    Matt's coolant system is not exactly stock. He has a homemade expansion tank that looks like it holds almost another gallon of coolant.
  36. #76
    Apr 05 2016
    Portland, OR
    I thought he hasn't had a chance to fit that or his meth injection yet...
    Beats me, I cannot keep track of the crazy things he is doing
    Geoff
  37. #77
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by colby7 View Post
    The crank pulley change is more involved than the sc pulley change.
    I disagree
    The crank pulley swap is actually faster than the supercharger pulley swap.
    Once the vehicle is in partial service mode (i.e. front clip slid forward 3") you can swap the crankshaft pulley in under 10 minutes. It takes longer to warm up the betty crocker oven....
    The trick is noting where the offset hole is. On the OEM crankshaft pulley there are 2 dimples on either side of the offset hole. What good practice would be is to install an exhaust manifold stud or any M8 x 1.25 stud into the offset hole , install the aftermarket crankshaft pulley using the other (7) M8 bolts and then removing the stud to install the final 8th bolt.
    Quote Originally Posted by eurotic View Post
    I am hoping that the tunes will evolve over the next year that stacking wouldn't be required.
    They will evolve now that tuners are more comfortable with not having a crankshaft pulley fail.
  38. #78
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    I recently added a extra coolant pump as well. Also running 2 stages of W/M
    So at this point I'm not too worried about heat..Also have something else in the works that will yield crazy low IAT temps (well let's hope so)
    Sent from my SM-G900W8 using Tapatalk
  39. #79
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by s4matty View Post
    The thermal reduction plates Loe was talking about?
    I doubt they will yield crazy low IATs. What are you going to do add a NOS shot to your intake? Tap into the AC system?
    Geoff
  40. #80
    Aug 15 2015
    2 feet
    Niagara canada
    I'm not taking about thermal plates..Making a quick connect killer chiller set up..no cutting of ac lines..It will simply connect where you fill ac via a 3way quick connect!!
