Results 1 to 4 of 4
    Active Member One Ring IreneO's Avatar
    Dec 30 2009
    Missing part on new HPFP
    I bought the newest HPFP (06F-127-025-M) however, it doesn't have the screw & cap that plugs the hole next to the low pressure sensor. My 2005.5 HPFP just had the sensor. Anybody know the part number for it or did I buy the wrong pump? I tried to use a security t25 bit on the 2 screws on both units to try to swap out, but they wouldn't turn.
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    You mean the hole that's on the front right in the pic?
    Yes, there's a separate shrader valve and cap. My Audi dealer f*ed up when they replaced my hpfp and put the wrong fitting in which ended up leaking and causing major problems.
    The part numbers for the correct valve and cap listed on my work order were:
    06D133400A - Valve
    06F133355A - Cap
    I'd confirm the correct part numbers but these were for a 2006 2.0t with the latest hpfp revision.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I'll confirm those numbers. You're looking at about $7.89 worth of parts.
    They're essentially made of butter as well. Be careful when tightening it to not over torque it. You'll see why when you need to remove it.
    Having said that, you'll need to torque the HPFP studs down BEFORE you install the check valve. It completely blocks access to the bolt head.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Dec 30 2009
    Awesome! Thank you for the part numbers and tips!!!!!!!
