Results 1 to 4 of 4
    Sep 17 2015
    United States
    where do I start on this list of vag-com error
    hi everyone,
    I managed to find time to do a little work on the car today and be able to connect my laptop with KII-USB cable to my car and performed AUTO SCAN.
    this is what I got from the complete list
    VCDS Version: Release 15.7.4 Running on Windows XP x86
    Data version: 20160216
    www.Ross-Tech.com
    Saturday,25,June,2016,19:17:09:01505
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAULT68E13A174307 Mileage: 180220km-111983miles
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E0 909 559 E HW: 8E0 909 059
    Component: 3.0L V6/5V G 0001
    Coding: 0016751
    Shop #: WSC 63351 000 00000
    VCID: 3773D3E6454865868F-513C
    No fault code found.
    Readiness: 0110 0101
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8E0 927 156 Q
    Component: AG5 01V 3.0l5V USA 0912
    Coding: 0001002
    VCID: 3C79CCCA7C6E46DE62-513C
    1 Fault Found:
    17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
    P0702 - 003 - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 0.0
    Torque: 212.0 Nm
    Temperature: 34.0°C
    T.B. Angle: 0.0°
    (no units): 4.0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 H
    Component: ABS/ESP allrad 2328
    Coding: 04497
    Shop #: WSC 00000
    VCID: 2D5FF18EE714DF56E5-513C
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 00000
    VCID: 63CB57B6F150592603-513C
    5 Faults Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    41-10 - Blocked or No Voltage - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul USA 0305
    Coding: 00013
    Shop #: WSC 63351
    VCID: 3469E4EA043E8E9EAA-4B00
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 C
    Component: Airbag 8.4EP 2000
    Coding: 0010607
    1 Fault Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 02041
    Shop #: WSC 63351
    VCID: 3C79CCCA2C6E46DE62-4AE6
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    49-00 - No Communications
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 L
    Component: KOMBI+WEGFAHRS. RB4 D35
    Coding: 03200
    Shop #: WSC 08212
    VCID: 3265E2F2FE2A80AEB8-513C
    WAULT68E13A174307 AUZ6Z0B0234870
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0305
    Coding: 00002
    Shop #: WSC 08212
    VCID: 71E72DFE3BACFBB681-4AE6
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6BDB3F9619801166BB-513C
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1311
    Coding: 11848
    Shop #: WSC 08212
    VCID: 72E522F23EAAC0AE78-4AE6
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0002
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D08
    Coding: 00060
    Shop #: WSC 63351
    VCID: 0409742A141EFE1E5A-4B18
    1 Fault Found:
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 F
    Component: symphony II NP2 0051
    Coding: 01005
    Shop #: WSC 08182
    VCID: 2A55FA92D6FAC86E00-4E94
    End-------------------------(Elapsed Time: 05:04)--------------------------
    there are a few problems that I currently experience.
    1) airbag light is on. i think this is show in the error code on driver side airbag. I disconnected the airbag in the steering wheel before to fix the electrical connections (clean). I tried to clear this code and rescan, it reappeared right away.
    2)ESP light. it was on for a while and then It just turn off today but then intermittenly on and off. don't know if this contribute from MAF sensor?
    3)try to connect to steering wheel electronic module and it say fail to communicate with the module. error show above
    4) transmission Error code above. that is the most scary part.
    I really don't know where should I start :(.
    Olivier
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    delete it all and see what comes back. could have been storing codes for years.
    Jun 02 2016
    San Angelo, TX
    Quote Originally Posted by heywier427 View Post
    +1. Who knows how long those codes were there.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Sep 17 2015
    United States
    I deleted it all 2 times and the above list was my latest scan from yesterday.
