Results 1 to 15 of 15
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Heads up, front coolant pipe nipple is very brittle.
    Well found this out today. The small nipple coming off the front coolant hard pipe will become brittle over time. The pipe is made of plastic, so it's a matter of time it will fail.
    I always wondered why Audi went with the plastic lines as when I had my b5, the plastic tee on the coolant tank would always break.
    The front hard line is made of this exact material as the old b5 tee is.
    The nipple that connects to the coolant res line just gave way on my today.
    When I extracted the broken part from the hose it just crumbled.
    I was debating buying a new pipe, but you have to get the car into service position to get it out.
    I decided to cut off the remainder and tap it and use a brass barb.
    I used a 1/8 npt barb with 5/16 nipple.
    Here is a pic: hope this helps anyone that runs into this same problem.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Hmmmm
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    I 100% agree that using plastic on something that gets hot and cold over and over was a bad idea. Glad you came up with an easy, quick and cheap fix brotha!
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Did you have to cut off the remainder? I was thinking of tapping into what’s left of it. Or capping the old one completely and tapping into a new spot on the pipe
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU Tune, Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - Custom E85 tune W/ FE STG2 Turbos, JHM TCU,Meth, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Established Member Two Rings DriveBikeRun's Avatar
    Dec 15 2018
    2014 Honda Odyssey, LOL
    Louisville, KY
    Resurrecting this because it was helpful and may help others. I didn’t even realize that the nipple had broken off until I was reassembling everything because it broke off inside the rubber hose to the reservoir.
    I shaved off what was remaining of the nipple and tapped a hole in that same spot. Had a small leak through the fitting threads even after using Teflon tape, so tried using JB Weld (marine weld version) and it’s sealed up like a champ so far.
    Veteran Member Three Rings Dorny1's Avatar
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    Had the same issue...Wish i would have seen this, bought a new tube instead.
    2010 Audi S4 GIAC Stage II, H&R Sport springs/Koni Yellows, USP Intake, AWE Track exhaust.
    (SOLD) 2001.5 Audi S4 Stage III
    "I love my mullet exhaust...Quiet in the front, Loud in the back"
    Mar 31 2008
    eS-4
    CAL*SO
    same thing happened to me. got it replaced when did the pcv/ water pump
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Same
    Been like this for over 20k miles
    Junior Member Two Rings
    Oct 09 2022
    This just happened to me. Suddenly coolant was pouring down under the car, I must have bumped this line (currently tearing it down for PCV and misc maintenance). What a ridiculously chickenshit design. This is why I hate newer cars. Many years of working on older 911's and Ferraris, and this Audi in comparison is a snap-together model airplane kit. Except the plastic is a decade old and has been heat cycled a thousand times and crumbles like chalk. Cheap cheap cheap.
    For those who tapped a nipple, what did you use to seal it?
    2011 S4
    993
    Early 911
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    For this very reason, when I did my engine out service at 97k miles (chains and just about everything possible) I replaced ALL of my coolant lines and hose ends. The heat this motor creates is insane.
    I purchased an 8P A3 with 175k miles recently as a project car and as I removed the engine, all of the hose ends have broken from being brittle. I’ll be doing the same massive replacement of parts on this as well!
    Feb 08 2013
    2017 Corvette Z06; 2007 Ford F-150; 2004 Honda RC51
    Sammamish, WA
    Similar circumstances here. I put the car in service position to clean the carbon from the Secondary Air System, and decided to the do the PCV and water pump/thermostat at the same time. Ordered all new hard coolant lines just to avoid having one break during the work, or at any point in the future. I just don't trust plastic, particularly after 170K miles and all the heat cycles that come with those miles.
    2013 Premium +, Monsoon Gray, S tronic, sport diff, B&O, 19" RS4 reps, black on black interior, carbon inlays
    Mods planned: seeing doctor tomorrow about a lead foot prosthetic
    Junior Member One Ring san_diego_s4's Avatar
    Jun 15 2023
    San Diego
    Could you share which coolant lines you replaced and where you bought them?
    Jun 15 2023
    San Diego
    I had the same issue as others on this thread. Was working my way through water pump/thermostat/PCV/carbon cleaning and noticed that the nipple had broken off somewhere along the way. I’ve got my car in service position already so will just replace the whole pipe.
    Jan 19 2019
    Horsham PA
    Quote Originally Posted by san_diego_s4 View Post
    At least for b8.5 (my15), the part number that I used was VAG-06E121045BB
    And if you're doing PCV and all that while you're in the valley, the part number for the coolant pipe there is VAG-06E121065N
    Jun 15 2023
    San Diego
    Awesome, thank you! Those are the two I’m replacing while I’m in there, just wanted to make sure I’m not missing any additional ones.
