Results 1 to 10 of 10
    Veteran Member Three Rings xquizit's Avatar
    Jul 25 2007
    '18 Cadillac Escalade, '19 Mercedes G550, 2018 Audi R8 RWS
    Jacksonville, FL
    Adams H2o guard and gloss clea paint damage?
    Washed my family car using the Adams Shampoo after rinsing it off sprayed the car with detail spray and began using h2o on the hood. Due note it was a solid 98 degrees out with high humidity. After spraying I quickly wiped the hood off and noticed a weird looking spot that looked like gum. However there was nothing of the sort there while I was washing. I tried a side panel and got the same result in another small spot. Now I have two questions 1. Is this product prone to burning through clear coat if used in the heat? Also, will the only way to fix this be by reprinting? See the images below.
    Car: Ibis White 2014 RS5 4.2 FSI V8
    Mods: Accuair | Brixton Forged M51 20x10.5 | Ecodes | Eventuri Intake | Eventuri Slam Panel | Balance-it Rear Valence |
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    That is bizarre. The G&G is a simple sealant and as such, isn't something that would/should have any abrasive or corrosive properties whatsoever. I've used it in similar conditions many times. Browsing the web, cannot find a single other report of anything like this. In fact, I don't think I've ever heard of any sealant causing paint damage.
    Does this car have factory paint?
    Can you describe what we're seeing in the pictures? Is that the actual paint that has softened and "gummed up" in the first shot, and in the second, has the paint been stripped from the panel?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jul 25 2007
    Jacksonville, FL
    Quote Originally Posted by LINDW4LL View Post
    I looked online as well and thought it was weird.
    It is factory paint. The first image is the hood it was originally like the second picture as I was wiping down the car and noticed the spot. Unsure what it was I wiped again removing that bit of clear coat. I then tried the side panel second image and then saw the same type of spot after spraying. It is the gummed up spot.
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    I have never seen anything like that, WOW. Have you called them up, we have used this on 100's of cars with no side effects like that.
    Were you able to remove it?
    Jul 25 2007
    Jacksonville, FL
    I have called and posted on their forums. Haven't heard back since I emailed their team but figured it's been busy since the fourth. I will probably give them a shout tomorrow to follow up.
    Jul 25 2007
    Jacksonville, FL
    Quote Originally Posted by xquizit View Post
    As for removal no. I polished the area with my flex or 14-2 and it cleaned the area up but nothing more.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    That doesn't look like anything caused by the product. IMO it's just a very textbook image of clear coat failure.
    I had a friend stop by with her 2012 Honda Accord (Black) and as I was cleaning it I noticed the same thing. she thought it was tree sap or something but it was clear coat failure.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    This defect was likely present before washing the car. The Adam's products just finally got your car clean enough to see it.
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Jun 17 2016
    Gaffney/SC/Upstate
    It almost looks like sap to me, being as in the polished pic, it looks like it got moved around. Take some alcohol on a MF towel and hold it on the area to see if it makes it able to wipe off.
    HUMP
    May 17 2012
    Houston, TX
    Expired/old product maybe? Not mixed or shaken? I'm assuming there is a shelf life that may have been exceeded. Also if the product has a low tolerance to temperature it may have reacted to the temps on the surfaces. Wierd though I would def call manufacturer for explanation
