Results 1 to 21 of 21
Thread: How not safe?
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    How not safe?
    How not safe is it too drive on tires like this? I am going to change out ASAP but was unaware of how bad they were on the insides. It seems to just be the front left tire that is like this so I will be needing an alignment also. Just wondering if it will be safe to drive on for a few weeks while I wait to be shipped tires? If not I could replace them with whatever the tireshop has in stock for a temp fix.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    few weeks? i wouldnt even drive like that for a day
    Mar 21 2015
    I wouldn't go another day on those. That's real bad.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Tire rack should be able to get you tires within a day or two.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Aug 08 2008
    2017 Q5
    Houston, TX
    yeah, don't drive on that. glad you haven't had a blow out already.
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Apr 27 2014
    United States
    Thats what I was thinking. Would driving on the spare be fine with the tread difference?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by B8 S4 View Post
    Yes, that's fine. Just remember it shouldn't be taken over 55mph or driven for more than 75 miles or so.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    ^+1 and get your toe checked right after you put the new tires on.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    You can drive on it but not far or fast. If you have a spare that's a better bet and tire rack should get you rubber within a day or two.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Yea that's about to blow. It's from positive toe. Mine blew out at about 105 mph on the I10 in down town Phoenix. That was an exciting morning.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Apr 14 2016
    Austin Texas
    Don't.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    How does your tire get that bad without you noticing?!
    ...and why would it take a few weeks to ship tires? You can get new tires to your door in a matter of a couple days.
    Jul 28 2009
    Philadelphia PA
    all it takes is the perfect amount of toe with negative camber and the tires chew up really quick.
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by MrFunk View Post
    Is your car always on a lift? With 9.5" wide back tired it's not the easiest thing to notice.
    c8 a6 allroad
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    That should buff right out.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Mine weren't even that bad and I replaced them. I suggest not driving on them as others have said. Tire rack had Pilot Super Sports to my door within 2 days...
    Apr 27 2014
    United States
    I ended up putting the spare on last night since I do not want to take chances since it looks pretty bad. I have always checked the tread but wasnt aware that it was camber wearing that much, my friend actually noticed it when I was parked at full lock. Other than full lock it is impossible to check on that part of the tire wear. I will have to wait till tomorrow to call a local tire shop when they open to see if I could ship the tires there......
    Any new tire suggustions? Mine were Nexen SU1s and were decent with traction and lasted awhile. Was looking at PSS but if something has similar performance and wear but for cheaper I would look into it.
    Apr 04 2012
    MSP
    You can go with Hankook V12 tires. A good road tire that is often compared to the PSS's at half the cost.
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    If you have $800.00 sitting in your account doing nothing, a set of Michelins is a breeze!
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    Don't be like Cosmo Kramer and see how far you can go on those tires!! Time to get em changed NOW!
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Apr 27 2014
    United States
    Quote Originally Posted by Arn560 View Post
    $800? All I have seen are $1000 for four. I will probably end up going with PSS but just exploring my options.
