Originally Posted by
S4_SH1640
Not to get off topic, but where did you get the yellow film for the foglights.
@bermudakid had some extra and gave it to me in exchange for some VAGCOM coding, but I believe it was 3M from Amazon. Heat gun is definitely needed to do the fogs, they're a compound curve so it takes a minute (and ideally a second person) to get it to sit flat).
doublespeeded
firstly a bit off topic, what did the rear brakes look like since you painted the fronts?
Also, with regards to headlights for the A4 facelift model, there was only ONE version of the LED lights right? sometimes it looks slightly different, im guessing depending on the angle.
I painted front and rear brakes. They all looked surprisingly good for being stock.
Edit: pictures here.
https://r.tapatalk.com/shareLink?url...e_pid=10887262
You're correct about the headlights, Prem+ and Prestige US-spec cars have the same headlights (along with Premium trim cars, if they have the lighting package). Same overseas, although they have a different version as mentioned before.
Sent from the Pedal Responce boardroom
