    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    Question for 20" wheel/tire people
    Put this up in the wheel forum and thought I'd do so here as well.
    I ran into an issue yesterday when swapping out my current 20" wheels for a new set of 20" Vorsteiners swapped. Wheel specs between old and new are the same so I was planning to use my existing Continental ExtremeContact DWS 275/30/20. BUT, when they pulled the tires off the outgoing wheels they discovered that the side walls were deteriorated (cracks and debris) and would need to be replaced. These tires are only ~year old with maybe 10-15K miles on them.
    Under inflation of the tires is the only thing I can think that would cause this premature degradation in the tire side walls aside from a mfg defect. I've been running 35-38 psi on the tires.
    Question: Is this pressure too low for a 275/30/20 tire?
    A new set of the current DWS 06 tires were ordered and will be mounted today. The Discount Tire computer recommends pressures of 32 front, 38 rear...
    What pressure are the other allroad, 20" wheel guys using?
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    I'm surprised you didn't file a warranty claim. Sidewall deterioration sounds like a materials thing, I.e. manufacturers defect. Unless you had the tire repaired, out something that actually void the warranty, to should be able to get a new tire (free for < 12 months, pro rated for more).
    As to the tire pressure, although those numbers are on the lower side of what people put in, that's not under inflated.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by jokingjimmy View Post
    I agree, the deterioration could be a mfg defect. Hard to prove possibly. Tires were purchased online when I picked up the outgoing wheels. Discount Tire wouldn't be the one to warranty them I think. I'll mention it today none the less.
    I wouldn't think the pressures would be under inflated either. Curious what others are going with...
    Established Member Two Rings PyroDonkey's Avatar
    Oct 08 2014
    My tires are set around 35, too. (Although I'm 255 width). May be worth looking in to a warranty claim if you can.
    Senior Member Three Rings burg3ngold's Avatar
    Apr 13 2016
    Washington DC Area
    I have 20x10 vff 104s wrapped in Evo 2s... 275/30/20... What psi should I be at?
    Sent from my ONE A2005 using Tapatalk
