Results 1 to 33 of 33
Thread: Drone be Gone!
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Drone be Gone!
    I'm so proud of this I'll even create a longer post than I normally would.
    I started with a custom magnaflow exhaust a few months ago buying the same rear mufflers and resonated x pipe that comes with magnaflow's exhaust kit, even the same tips. With 2.5" piping and installation, I paid less than half of what the full system costs. I chose this system because all the reviews and sound clips indicated that it was just slightly louder than stock with no drone. I was wrong. The overall sound wasn't bad, but the drone was CRAZY loud, especially up hills. I dealt with it for a few months as the drone only existed in certain rpms. Over time It started to bother both my wife and I, so I started looking for solutions. As tempting as it was, I couldn't justify the cost of the awe system. I ended up just changing out the rear mufflers to borlas, again after reading reviews and listening to sound clips. Wrong again. The exterior sound was better, but the drone was still there. I basically had to drive in S mode all the time to make it bearable.
    After more research I learned about helmholtz and side branch resonators. They seemed like a cure all for sure. If you're not familiar with this, Google it, plenty of information out there. The only problem is finding the right length and size. I took the plunge and ordered a pair of 12" no drone resonators from Synapse engineering for $50 each. Took them to a muffler shop today, and even the installer was skeptical. After the short ride home, I couldn't believe my ears, NO MORE DRONE!!!
    I even drove up an uphill stretch of freeway that in the past, made the drone so bad, I felt like my ears would blow. With the new resonators...Silence! I love my exhaust again.
    Here's a picture of one of the resonators. Synapse recommends that they should be installed as close to the engine as possible, but there was no room so I had them installed at the rear mufflers.
    If anyone decides to go this route I will add one disclaimer. I completely guessed on the size and length and got lucky. There are many different ways to do this so please do some research. But it does work.
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    Sound clips please
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Sep 10 2015
    VA
    I'm also always skeptical about people who say there's no drone. It always is and it's pretty bad every time I get to hear it. I'm not sure if they are def or just like that sound. I can't stand it. Some cars drive by me at times and the drones so bad it feels like my heads about to implode yet may be way worse in the car.
    Wish there was some system to measure drone on each system in a decibel kind of rating.
    Jul 30 2013
    Colorado
    I have the full Magnaflow exhaust (off the shelf), and yes the drone is hideous. Do you have the Synapse part number? I need to find a solution. Thanks
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by all_kobiwon View Post
    ND12MS is what I used. It worked for me but may not work for everyone. Good luck!
    Jul 30 2013
    Colorado
    Thanks man!
    May 23 2016
    Raleigh NC
    Thanks for the write up. I've been planning on doing borla mufflers with magnaflow x pipe resonator. So now all I need are the secondary resonators.
    Did you replace the front mini mufflers with magnaflow x pipe and remove center muffler?
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by Adrenalin Junki View Post
    I have awe res dp up front. I forgot to mention that in the first post.
    May 23 2016
    Raleigh NC
    Ok thanks for the info.
    Established Member Two Rings bthomas22's Avatar
    Aug 26 2015
    Cumming, GA
    Glad to hear this, Ntsantos. I have the Magnaflow system installed and will give this a try as my drone is also horrible. I assume you went with the mild steel vs the SS...any reasoning behind that choice?
    2012 A7 Premium Plus Sport- APR Stage 2+ - Dual Pulley - AWE Quad Exhaust - AWE Resonated Downpipes - Roc Euro Intake - HRE FF01 Liquid Silver Wheels, 20x10.5 square setup - H&R Lowering Springs - RS7 Grill - S7 Rear Valance - 034Motorsport Drivetrain Mount Package - 034Motorsport Control Arm Kit - 034 Rear Adjustable Swaybar
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by bthomas22 View Post
    I went mild steel only because my piping is mild, or aluminized steel. If I had SS piping I would have went ss.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Quote Originally Posted by ntsantos View Post
    Did it also change the tone of your exhaust or just eliminate the drone at low rpm?
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by madyspop View Post
    No change to the exhaust tone. Mine is still loud. It just removed the annoying drone that used to occur at about 1700 rpm.
    Nov 19 2005
    Central IL
    Did you have one put in on both sides?
    Dec 06 2015
    San Ramon, CA
    Yes sir.
    Jun 18 2011
    markham, ontario
    So I did the x-pipe mod with Magnaflow last week. I love the sound. At around idle, there is a very deep sound, I like it, can't feel it so I wouldn't classify it as drone. The car is slightly louder overall.
    Issue is, once the windows are up, the deep sound completely disappears. I am quite certain this is the B&O active noise cancellation kicking in. I recall reading that it disables ANC if the windows are down. From a little time experimenting, it seems like at least 3 windows need to be opened to disable ANC.
    I have tried reducing Soundaktor to 0% without any effect. I have tried taping the 4 ANC microphones on the headliner without any noticeable effect.
    Does anyone know how to perform a sound system adaptation? I recall another thread that mentioned this but cannot find it now. It was related to exhausts and drone and the adaptation fixing it. In my case I just want to see what it does after adaptation. Thanks.
    23 BMW X3 M Competition Brookyn Grey, 17 Golf 1.8 TSI Pure White
    -Traded-in-
    19 RS3 2.5T Nardo Grey, 18 Golf R DSG Indium Grey, 13 S6 4.0T DSG Phantom Black, 11 Golf 2.0TDI DSG Candy White, 11 S4 3.0T S-tronic Ibis White, 10 Q5 3.2FSI 6A Ibis White, 01 Golf GLS 1.8T 4A Black, 06 A3 2.0T DSG 6A Brilliant Black, 04 A4 1.8TQMS 6M Ocean Blue, 00 A4 1.8TQMS 5M Light Silver, 99 Golf GL 2.0 5M Candy White
    Nov 19 2005
    Central IL
    Quote Originally Posted by GolfGL View Post
    Would love to read this as well?
    Jun 11 2013
    is too small.
    So. Cal
    The AWE touring exhaust uses these resonators, which is why there's no drone with it. Nice work getting a great-sounding exhaust without the drone and without spending four figures.
    "Hauling ass > new car smell" -HeelBuff
    Nov 19 2005
    Central IL
    Quote Originally Posted by Delurker View Post
    AWE must have them built in their cans because I had that system and also have it on my B8 S4 and there isn't anything on the outside.
    Jun 11 2013
    is too small.
    So. Cal
    Yep, in the mufflers
    Junior Member One Ring
    May 11 2016
    East Coast
    Interesting, could you please take another picture from under the car showing exactly where the hole was cut and the resonator was welded in? I've got a little bit of drone and will give the synapse ND's a shot.
    I have the Magnaflow catback 19159, but our mufflers look nothing alike, probably contributes to the resonance noise? Huge size difference:
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    Just curious:
    Isn't a muffler supposed to surprises noise and the more noise it eliminates then the better the muffler?
    In Harley Davidson land, just throwing away the muffler is more pleasant?
    Sometimes logic doesn't make too much sense.
    2014 A6 Prestige. VCDS, Chipwerke.
    Dec 06 2015
    San Ramon, CA
    Here's another shot. Hope this helps.
    May 11 2016
    East Coast
    Quote Originally Posted by DB22 View Post
    Just curious:
    Yeah but your Harley gets A LOT louder when you remove the factory mufflers and put on a screaming eagle exhaust, right? I'm trying to make more power and have some level of sound comfort
    May 11 2016
    East Coast
    Oh, I see, they're Borla. Slightly ifferent 2.5" oval muffler case and sightly different packing than the Magnaflows... that explains the size difference.
    Yes that picture helps a lot, appreciate it. There's a little pipe section between the 2.5" inlet and the Synapse piece to space it out away from the Borla unit. Was just curious how it all fit in there.
    On the Magnaflow catback the mufflers are bigger and occupy more space from the swaybar to the edge of the factory sound insulation. They're pretty tight to the bumper housing, I'll have to get creative with space and placement.
    Thank you!
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by Sinitron View Post
    Thank you!
    The best spot according to Synapse is closest to the engine. I was going to put them before the center muffler but they didn't fit. Not sure of your case but that would be the spot if it fits. Also, if you have stock downpipes, there is a lot of room by the stock resonators.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Is there some kind of device inside the synapse pipe or is it a simple 90 with a welded cap on the end?
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by goliath1 View Post
    Just a pipe and cap.
    Active Member Two Rings brodie's Avatar
    Dec 27 2014
    H2 SUT|Hellion Cobra|B5 S4|C7 A6
    Columbia, MD
    Interesting! I will be giving this a try on my Magnaflow exhaust this week. Thanks
    Dec 06 2015
    San Ramon, CA
    After a good few weeks with this setup. I decided to go another direction. I've been on a oem plus theme on the car and ended up installing a S7 rear diffuser and S7 sport exhaust (thanks Tireguy!)
    Ive come to the conclusion that the side branch resonator is definitely legit and a low cost way to achieve your desired exhaust sound.
    After much thought, I decided to put up my Borla mufflers with the Synapse resonators for sale. If anyone is interested, they'll be up on the classifieds soon.
    Apr 13 2014
    RI
    I have the sport exhaust and love it. Just enuf growl to make me smile but keep the neighbors happy
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Dec 06 2015
    San Ramon, CA
    Ot actually made my wife happy...which should make my life happy?
    I'm still getting used to the quietness, as hard accelerations aren't as aggressive when I had the Borlas on.
    Apr 01 2012
    2004 Audi S4 - JHM Short Shifter, 034 Motor Mounts, Apikol Snub, H&R Springs, H&R Spacers - SOLD
    Minneapolis, MN
    What car did you add the ND12MSes to? C7 A6/A7/S6/S7/RS7?
