Results 1 to 3 of 3
Thread: Need Your Help
    Jul 09 2015
    Santa Barbara
    Need Your Help
    Evening, Gentlemen
    This past week i pulled my engine out and replaced the AC compressor, did the timing chain service, new clutch, new adams rotors, and JHM piggies. After, I got the AC system checked for leaks and filled and everything was going swell until last night when the AC started blowing hot air. The fans both turn on when i put it on AUTO and i had my local shop re-check my AC system today and its still filled and has pressure. When i installed the compressor I filled it with the correct oil and amount, everything was connected back the way it was supposed to. No check engine light. Am I missing anything else as to why the compressor no longer turns on? Any help would be appreciated. Thank you.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by BlueLucifer View Post
    Evening, Gentlemen
    It could be the AC pressure switch on the condensor. If you have VCDS, scanning the climate control module will give you a better clue.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    yup, get codes from the auto HVAC module
