Results 1 to 13 of 13
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Angry Back for STG2 Oil Consumption
    Well after the car failed STG 1 because the light came on at around 450 miles into the test I have now brought the car back to Audi for STG 2. I was told that even though Audi corrected the problem and most 2012s don't have the consumption issues apparently where my car was built towards the end of 2011 it fell into the category of the motors that had the problems. I have used 0W-40 Mobil 1 since I have owned the car and only put about 10k miles of the car in the last year, I do all my own maintenance unless I have an open recall I will take it into the dealership. I would say since owning the car I have put in about 6 quarts of Mobil 1 in the last 10000 miles not including the 4.9 I did when I changed the oil for the first time at around 5000 miles after ownership which had me thinking I had a leak somewhere but I never had oil under the car or in the skid plate but I still went looking and the motor was spotless no signs of leaks anywhere so I called the dealership I purchased the car from and they told me to bring it in. After Audi went looking for leaks and doing some other things they ended up doing the STG 1 test and sending me on my way and told me if the light came back not to add a quart and get it back to them asap, or bring the car back after 750 miles. I made it around 450 miles and got the add 1 quart message so off to Audi I went. I am going to have the timing chain done while the motor is apart and was told they would only charge me for parts which comes to $400, I am early but I don't feel like doing it in another 60k miles so I am letting them go ahead with it. I have done many timing belts and chains in the past so I know I am capable but I figured if they have it apart I will let them have all the fun. . I did the timing belt and rear cam chain and tensioner on my B7 right before I was hit and the car was totaled out and it was pretty simple I feel I could do the chain and I like to do my own work so I know it is done right but maybe the next 100k I will have the chance to do it myself. I was giving a brand new 2016 Q3 with 12 miles on it so driving it back to the shore I put another 140 miles on it, not a bad SUV but I would rather throw the money at a Q7 if my wife ever wanted to get rid of her 3.2 A3 S-line as the Q3 feels like a lifted version of her car lol.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    May 19 2016
    SWFL
    I just got stage one done a few days ago... Not burning oil as fast but I know I'll have the add oil light on by the end of the week. Haven't paid a dime so far so in assuming stage 2 will be taken care of for me
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I'm surprised to hear that. I thought oil consumption was addressed after 09-10, with a few cases trickling over into 2011. Regardless, I wish you the best of luck and hope Stage 2 fixes your problem! Keep us updated.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jun 30 2009
    Washington DC
    At least they are doing with no questions ask. Cup half full
    Jul 14 2012
    Eastern Shore,MD
    Well they did try telling me at first it had to be a leak after I had inspected the car myself, and that the update would solve the problem if no leaks were found which did not change anything imo. I will keep everyone updated.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by B7AudiSline View Post
    Car have stock software?
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Jul 14 2012
    Eastern Shore,MD
    Quote Originally Posted by hyperunion View Post
    Yes the motor is 100% stock, I was going to add a HFC and STG 2 in July.
    Jul 14 2012
    Eastern Shore,MD
    I still don't have my car back but was told yesterday that the chain had some stretching and they would of recommended the timing chain service if I had not brought it up before I dropped the car off.
    Mar 17 2014
    Los Angeles, CA
    How many miles are on your car right now? If you are a little higher on the mileage, it doesn't hurt to do the replacement while everything is already apart.
    instagram
    Jul 14 2012
    Eastern Shore,MD
    Right around 76k, I planned on doing it anyway when I knew they had to take everything apart but the tech said it would of been recommended anyway because the chain had stretched and the tensioner had wear.
    Jul 14 2012
    Eastern Shore,MD
    I was told when I mentioned it to the service advisor that I wanted the timing chain service done "that it was not required until I reached 125k". I was glad they let me know that I made the right call.
    Jul 14 2012
    Eastern Shore,MD
    I picked the car up today timing chain service with all new parts ran me $368 plus I was able to use a 10% off coupon . The car feels different in a good way, acceleration seems smoother and the car is quieter. I also noticed my MPG increased on the way back to the shore I was getting 20 MPG when I dropped it off and pulled 25 MPG on the way home.
    Jul 14 2012
    Eastern Shore,MD
    BTW I was told by the service advisor they are doing at least 10 of these tear downs a month for oil consumption problems.
