Results 1 to 11 of 11
Thread: Check valve
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    Check valve
    Is out check valve a sealed piece or a snap together? Seems mine has come apart or unsnaps
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Which check valve?
    Established Member Two Rings JS4Avant's Avatar
    Dec 01 2014
    2004 dodge 2500
    Battle Ground, Washington
    Do you mean the Crank case vent? If so yea they come apart, should snap back in
    Jul 12 2012
    May 18 2012
    2005 S4
    Portland, OR
    It's sealed. I just replaced mine, which helped with rough idle. Mine was rattling and the new one doesn't. Also, you can get the OEM brand for like $20.
    Oct 05 2015
    Billings, MT
    ahh, yeah just replaced mine also, I also rubbed some high temp bondo around the top edge and let set. now it is extra safe.
    Jul 12 2012
    if mine is faulty could it cause these two codes
    17535 - Fuel Trim; Bank 1 (Mult)
    P1127 - 002 - System too Rich - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194089 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3345 /min
    Load: 13.7 %
    Speed: 107.0 km/h
    Temperature: 96.0°C
    Temperature: 45.0°C
    Absolute Pres.: 820.0 mbar
    Voltage: 13.462 V
    17537 - Fuel Trim; Bank 2 (Mult)
    P1129 - 002 - System too Rich - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194090 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3198 /min
    Load: 27.8 %
    Speed: 102.0 km/h
    Temperature: 96.0°C
    Temperature: 45.0°C
    Voltage: 13.335 V
    i have replaced an o2 already cleaned my MAF and purge i was looking for loose tubes when i found the check valve issue
    May 18 2012
    2005 S4
    Portland, OR
    I find it really unlikely that the check valve would be the cause of that.
    Jul 12 2012
    Any idea what could be the code issues im kinda stumped
    Feb 18 2014
    Arizona
    I just replaced mine also. Apparently there was an update to that part as the older one was prone to coming apart, I wasn't able to find much about it in relation to the s4 but that's what I read in the a4 forum. Seems that either it comes apart more often for them or maybe the slight vac leak just gets noticed more since they're boosted. It will cause a vacuum leak but if I'm not mistaken that would be more likely to cause a lean condition, so there must be something else causing the rich codes.
    Jul 12 2012
    yeah im a lil stumped someone said i its a leak, or spark plugs or still my MAF im gonna start by the valve check the check my plugs
