Results 1 to 5 of 5
    Junior Member Two Rings
    Nov 06 2013
    Baltimore MD
    Question Timing Belt, What Else?
    I am about to replace the timing belt in my 2003 B6 A4 1.8t. I know to replace timing belt, tensioner, water pump and drive belt (we used to call "fan belt").
    Is there anything else I should replace while I am in there?
    And, is there anything else I should do while in there, such as detail the front of the engine, check engine mounts, stuff like that?
    Thanks,
    John
    2003 A4 1.8t 5 speed - my brother
    Active Member One Ring Afrckenway's Avatar
    Mar 11 2016
    Tampa Fl
    Some people change the coolant while they're in there. I actually finished up the same thing today, but I swapped from G12 to green prestone.
    It's always a good idea to check your mounts and bushings, and I always clean what I can get to while I'm in there. It'd be good to inspect your hoses
    too once the core is off. It's also said the valve cover gaskets usually go around 60k too, so it's something else to save hassle down the road. I'm still new
    to the board but hopefully its a good start
    Oct 02 2006
    Wadsworth,OH
    We have complete kits that include everything you need to perform a water pump/timing belt service!
    Kits are VIN specific so if you need to know which to order PM me your VIN and I'll be happy to help.
    Let me know if you have any other questions.
    Jason
    Apr 03 2016
    Up North
    Just don't go cheap on the tensioner... I did and regretted it. Uro one failed at 28,000km (17,500mi) after install. The belt jumped two teeth by the time I babied it home. Another tooth or two and it would have been really expensive instead of really annoying. I'll never buy anything Uro brand again.
    Veteran Member Four Rings V70R's Avatar
    Feb 14 2015
    PDX, OR
    Ahhhh yes, Uro parts :p. Couple things that come to mind while in service position are visually inspecting for any vacuum leaks (DV line, for example) and possibly front snub mount. Always good to check main motor mounts too for fluid leaks and/or cracking of rubber. If you have a dealer nearby, G12 is right around $22-23 per gallon and can save ya some additional money during your repairs.
    Xlite w/ 11spd Campy Record- 2005 Dolphin Grey Ultrasport Avant 6MT-- 2003 S6 — 2007 XC70
