Results 1 to 8 of 8
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: Billet Oil Filter Housing Hook-Up!| 8V A3/S3
    We don't know how you feel about it, but trusting your engine's most vital fluid to a plastic filter housing seems like a leap of faith. In fact, after repeated heat cycling and several oil changes performed with pliers and other makeshift tools, the original plastic filter housing body gets pretty ratty.
    To give back to the customers, we've decided to throw in a MANN-FILTER with purchase! Why not install a smart looking billet aluminum housing paired with a MANN Filter, and take the guesswork and risk out of filter changes.
    Hook-Up!
    Fits:
    Audi 8V A3/S3 2.0T (2015+)
    Jason
    Mar 24 2016
    UK
    Hi Jason, I fitted one of these at the weekend it's an excellent well made product. Only issue is that the pintle valve would not snap back into the oil filter support no matter how hard I tried so I had to refit the filter support tube without it otherwise I couldn't get to work. Any issues running without this ?
    Many thanks.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Rob2k68 View Post
    Many thanks.
    Not quite sure I follow. Do you have any pics so I can get a better understanding of what's going on?
    Jason
    Mar 24 2016
    UK
    Jason
    I can't upload pics on this site unfortunately.
    Referring to the billet oil filter housing installation instruction pdf from the ECS Tuning site, page 14 shows the exploded view of the filter support components, the spring, the pintle and the valve seat. On page 15 it shows that they should just snap back in which mine would absolutely not do after hours of trying I put the filter support into the billet housing without the spring, pintle and valve seat. I've ordered a new one from Audi and should get it today so hopefully that'll sort it out.
    Many thanks,
    Rob.
    Oct 02 2006
    Wadsworth,OH
    Ah ok. We haven't heard of any one having issues like that. Could just be that you're overlooking something in getting it reassembled. Not uncommon when working on these vehicles! None the less let us know if the new support tube corrects this.
    Jason
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Do you guys have the socket for the S3 oil filter housing? Last time I checked you did not have that tool.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Baggio View Post
    Its listed in the PDF which links you directly to the tool.
    Click HERE
    Jason
    Aug 28 2013
    Click HERE
    Jason
