Originally Posted by
Moncion
It was only once, first one was not actually thru clear. I think I have too many layers of clear lol, paint still isn't coming off, there's just an indent where the layer peeled.
You can see that the clear is missing in the last pic in your first post. Either that or it's a terrible picture. You'll know when you're through when the paint is a completely different texture. There is little resistance to moving your finger across it, whereas the clear likes to create a lot of friction when you drag your finger across it. Ask me how I know. Once or twice, it doesn't matter. I don't think you can put on too much clear. Unless you sprayed like ten coats on. Even then, I'm not sure that it would be something bad. Using spray cans also makes it harder. Not impossible, just more difficult to get the clear where you need it. I'd mask off the whole care to avoid overspray, even if you're doing it in the garage.
I also wanted to add to my last post that this isn't a permanent fix. The clearcoat will never flow out and bond with the existing clearcoat on the panel. This will just look good for a year or two. The only permanent fix is to repaint the fender. Oh, this is a rear quarter. Well, still, the only permanent fix is a complete sanding and respray (not the whole car, just the body panel, which I believe goes above the doors all the way to the front fender).
