    Established Member Two Rings Jeremy1607's Avatar
    Dec 29 2015
    Perth, Western Australia
    20x10.5" ET27 Wheels
    Hi everyone,
    I'm new here, I'm looking at getting the Niche Targa M131 wheels in the size mentioned above.
    I've got a 2010 A5 2.0T Convertible. I have browsed around and seen other members on this forum running the same set up, but they are all either on springs or coilovers.
    I was just wondering, I'm not really planning on lowering the car. Would this set up still look good on my car ? Or not, as they would poke out slightly and sit outside the guards, specially the fronts ?
    Thanks
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    It might end up looking like a 4x4.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Quote Originally Posted by HazeMyth View Post
    Agreed. I wouldn't run 20's unless you plan on lowering the car. 19's are the way to go on stock suspension.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Dec 29 2015
    Quote Originally Posted by Audiforumuser View Post
    I see, what lowering springs gives you the smallest amount of drop ? H&R OE, is it ? I notice you've got the KW H.A.S, what is the difference exactly between that and an actual coilovers system ?
    Mar 01 2010
    Saskatchewan
    Quote Originally Posted by Jeremy1607 View Post
    For just a spring, the OE's. The KW Height Adjustable Springs are nice because you can adjust the drop as you can with a coilover but they allow you to keep your stock shocks, this is especially nice if you have ADS (Audi Drive Select). The kit is a spring with an adjustable collar that slips over your stock shock. The ride is pretty close to OE. Happy with mine.
    Coilovers completely replace your shocks and springs. They'll cost you more upfront but allow for more fine tuned suspension adjustment and a firmer, more planted ride.
