Results 1 to 14 of 14
Thread: Roc-Euro Intake
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Roc-Euro Intake
    I'm doing some research and from what I read the Roc-Euro intake seems to be the best out there as far as making more power and better noises from the engine bay. With that being said I do worry about taking off the factory intake and box. Has anyone experienced any issues doing this? Water getting into the intake area?
    Mar 21 2015
    First off there are so many options out there now that you dont need to go with Roc and wait 3 months for it to be delivered. See the many threads about this.
    Second you would have to almost submerge your car for water to get into the intake. It's very easy to remove and add an intake.
    Established Member Two Rings Phrost2.0's Avatar
    May 02 2014
    Green Bay, WI
    I own the Roc-Euro. Install is very easy and takes literally 25 minutes if you take your time. As far as performance numbers you'll MAYBE REALISTICALLY gain 6hp. You get a lot of noise which is the best part. One way to look at it is you'll probably drive the car harder so gas mileage will probably decrease
    AWE Intake is basically just paying for all the CF.
    Roc-Euro all the way.
    May 17 2012
    Houston, TX
    Have and had intakes on all my cars and trucks. never an issue with water, unless you are constantly offroading through deep water and flying through it and flooding the engine bay... hopefully your not doing that in the S4... lol
    Lots of recent bad reviews on Roc Euro. You can probably find a lightly used intake for cheap in the classifieds or just spend a few extra bucks to get another intake in a reasonable amount of time.
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    I have had mine for 5+ years/60k+ miles. No issues whatsoever. Great intake, seems to be an issue with how long some orders are processed these days. Back when I bought it, John was very helpful and got it out to me quickly.
    I've driven with it through michigan blizzards, thunderstorms everything... Water will not make its way into the intake unless you do what AKPS4 mentioned lol
    Quote Originally Posted by Phrost2.0 View Post
    Just to add on. Bunch of us have found that it yields a tenth and 1mph in the 1/4 mile on tuned vehicles.
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Don't overthink it....it's an intake and the differences between brands (other than cosmetic) are negligible. "Best" is subjective. You should have no issues removing the stop box and replacing it.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    There are better designed intakes out there now with better customer support and faster delivery.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Established Member Two Rings Mr_Hooper's Avatar
    Jun 04 2016
    Littleton, CO
    I agree with most of what's said above. I actually cancelled my order with Roc Euro yesterday. Spoke with John & he cited some additional supplier issues (all-around nice guy from my interactions with him), but I just got tired of waiting, lack of communication, & empty promises. Hopefully he gets things together soon.
    Having said that, I went ahead & ordered the ECS Luft-Technik system, based on recommendations around this forum (link here). But I agree, no significant difference between intakes. Go with what you like best, but be forewarned by the stories of others.
    2021 S4 Premium Plus Quantum Grey
    SOLD:2016 A6 Moonlight Blue
    SOLD:2013 S4 Premium Plus Estoril Blue
    Apr 05 2016
    Portland, OR
    I wouldn't do the Roc intake simply because of the poor customer service.
    When I was shopping I was looking at the ECS, CTS and USP intakes.
    Ended up going with the USP because they were having a special.
    Build quality is great, customer support is even better. (The filter I received was slightly damaged, they sent a new one no questions asked!)
    Geoff
    Registered User Four Rings
    Sep 06 2007
    Its actually 10+ on a stage 2 car.
    Jul 04 2008
    York, PA
    Sound comparison between the ECS and Roc Euro?
    Mar 21 2015
    Quote Originally Posted by 4Rings3Liters View Post
    Metal tube will always be a little louder than the CF tube. The silicone tube will be a little quieter then both.
    CTS makes a very nice metal tube intake that is pretty much a clone of the Roc but has better mounting for the shield and an aluminum bracket for the SAI filter instead of the zip tie like the Roc uses.
    Jul 04 2008
    York, PA
    Thank you!
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    In my experience, the filter media also makes a difference in sound. An oiled cotton filter with wire mesh will make a higher pitched, louder sound than a dry cotton filter with no mesh. This is from my testing with different intakes/media on my previous 2.0t
    https://youtu.be/liN2TevzFSY
    I agree with others, brand doesn't matter. Biggest difference is if you want a carbon showpiece or just a good intake. If you just want a good intake, shop the classifieds. I picked up a used USP intake for 150, and it's been awesome.
    https://youtu.be/YB__RrouHJo
    2021 Audi S4, P34 Intake
