Results 1 to 28 of 28
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    front lower control arms
    ok so i know there are poly bushings for control arms but is the ball joint serviceable? why arent people changing that out as well as bushings?
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I would just buy this kit, end thread. At that price, why service the ball joints.
    Jun 04 2013
    SE MI
    well, arent OEM CAs preferable to aftermarket? also, i want poly bushings. why would these be superior?
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    I personally would recommend the density line kits from 034Motorsport. Stiffer rubber without the NVH you'll get from poly bushings.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Jun 10 2013
    United States
    The OE style balljoints are not serviceable but should last a very long time if the boot is not torn. I suspect the companies that make the poly bushings do not sell the complete arms so you end up swapping bushings on regular style arms.
    Oct 30 2009
    Miami, FL
    Personally I think poly bushings on anything but a track car are a terrible idea, it's just not worth the hassle with the squeaks, creaks, constant need for greasing and short lifespan. The stock bushings are also designed to deflect in basically every direction due to how the 4 link suspension is set up, which is no bueno for stiff poly bushings. You'll end up limiting suspension travel and steering angle with poly bushings. That's one of the reasons you see all the serious adjustable control arms with heim joints instead.
    2018 S5 Coupe - stock for now
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    i wasn't impressed with the FCP kit when i installed it 3 yrs ago because it seemed like good bang for the buck. the rubber seemed super soft. i had to replace my bottom arms right away because the rubber just looked like it was going to fail from the get go where the shock attaches. maybe it has improved now.
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Jun 04 2013
    SE MI
    there doesnt seem to be the density line bushings available to push into the lower CAs on 034 website. are they only available preinstalled in the upper CAs?
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by estomax View Post
    The FCP kit is well-known to be crap, it's fine if you need to sell the car soon but they don't last. It's marginally better than the no-Name stuff you find on eBay but that's not saying much. You get what you pay for with control arms, there's no free lunch here.
    Jun 04 2013
    SE MI
    found the a6 density line and ordered the lowers for my allroad with steel upright
    Sep 03 2015
    Hobart Australia
    This thread is disturbing reading for me as I replaced my lower control arms just eleven months ago with parts I bought on Ebay USA. I paid only $180 for two arms and that included shipping to Australia!
    I just had another look on Ebay and saw arms which are supposed to be O.E.M. for $255 each and that does not include shipping.
    I hope it is not like the front Arnott shock absorbers that failed after seven thousand miles and which I replaced with genuine OEM Audi parts which were expensive.
    I suppose I have the option of replacing the rubber bushes which are apparently available as OEM parts but then they may not fit the Chinese made arms.
    Oct 30 2009
    Miami, FL
    The bushings aren't the issue with cheap arms, it's the ball joints and their rubber boots that fail. They also tend to be made of mystery pot metal rather than a controlled aluminum alloy, which is a bit concerning.
    Aug 10 2011
    330i ZHP
    Quote Originally Posted by Mad Cow View Post
    They are very popular on the B6. I've had mine installed for 80K and haven't had an issue. I would say it is well-known that how they are installed has a big impact on how long they last, but I wouldn't say it is common opinion they are crap.
    The problem with the FCP kits is that they're hit or miss, you might get Meyle arms that were made in Turkey(good) and you might get arms that were made in Taiwan/China(bad), depends on what batch they pull from when u order. So you might get lucky like this b6 guy ^ or you might get shit like me and be replacing an arm on your back in the winter in your driveway like me. Oh yeah and lifetime warranties are great and all, but they don't cover labor or alignments, so factor that in, every time one fails, gotta either do the work yourself or have it done, then get an alignment.
    I will always go with OE Audi arms in the future, and I am NOT rich, in fact quite the opposite by most standards.
    Veteran Member Three Rings das_boosthead's Avatar
    Oct 01 2009
    VA
    I had success finding TRW's at a reasonable price since they're normally carried by big companies like Jeg's and chains like Advance where you can use a 30% off coupon.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    ill say it again http://www.rmeuropean.com/Products/4...G80-V1399.aspx
    RMeuropean they sell genuine TRW c-arms.
    still riding on the ones i got 5-6 years ago, and prolly 75k miles
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Oct 01 2009
    VA
    Dont know if this is different than the TRW arms that RM sells (I like RM as well!)
    But they are a bit cheaper at $103 shipped. https://www.summitracing.com/parts/trw-jtc1297
    May 20 2010
    Disagree. Like MacFady, I have them on my car (B7 -- same suspension-wise as B6). I replaced the entire set of mine with the FCP kit, and they're doing quite fine 20k later. They may have had a quality issue at one time, but I could not ascertain a difference when I installed them last year.
    Jun 04 2013
    SE MI
    Quote Originally Posted by carmudgeon View Post
    those density line for the a6 dont seem to fit the allroad even though they say they will, and are giving me a massive wheel movement when the stresses shift from rearward to forward. unless im missing something.
    so looks like its buy oem allroad CAs and push in density bushings. if thats even possible
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    But I just got my FCP Lower Control Arms :(
    I keep having that feeling that PROPER installation counts
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Jun 04 2013
    SE MI
    ok yeah so that was right. proper installation indeed. we didnt torque down hard enough.
    also we made adjustment to the ride height the wrong way and ended up getting rid of the spring pre-tension. so ride height...check. clunks...gone. excessive movement of front wheel on braking...gone.
    its embarassing to admit this but hey there is a first time for everything. its riding great now. only need to finish up the back.
    this has been the funnest car to drive i gotta say.
    Active Member Two Rings In4cus's Avatar
    May 18 2016
    2009 A6 Prestige, 2010 BMW 328xi, 2017 Ford Flex
    Dingmans Ferry Pa
    What is anyone's opinion on the Febi lower control arms?
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by In4cus View Post
    Have them on my Passat and allroad and they have been great so far.
    Sent from my Nexus 5 using Tapatalk
    May 18 2016
    Dingmans Ferry Pa
    How long have you been running on them? I'm on a TIGHT budget, so the Febi's are what I can afford now.
    Oct 30 2015
    Massachusetts
    I lied, I'm only running them on my Passat (driving school car) and it's working great. I'm at 200k on her so we've had them on for a little over 10k miles. I ran Meyle HD and wasn't anything special and went through a few of those. Then again I am using it as a student driver's car, 1000 miles a week, we've hit so many pot holes and curbs so I'm not going to fault the product. The salt that they use to help melt the snow up here in the northeast probably doesn't help with the longevity either. I have found that no matter what brand you go with, installation is so much more crucial if you want things to last.
    My wife's allroad is running Lemforder from FCP Euro which offers lifetime warranty so their price is a few dollars higher than other retailers. 9k miles so far and no creaks/clunks of any kind.
    Which lower control arm are you buying and from where? Forward or rear?
    May 18 2016
    Dingmans Ferry Pa
    I am looking at the Febi's for the front. Pelican Parts has them for 78 each.
    Oct 30 2015
    Massachusetts
    Why are you replacing it? vibration? Clicking sounds? What I'm trying to get to is if it's not a safety thing, save up for lemforder or something from fcp so you can get lifetime warranty. Just a thought
    Sent from my Nexus 7 using Audizine mobile app
    May 18 2016
    Dingmans Ferry Pa
    Quote Originally Posted by AllroadMass View Post
    They are worn. The front is sloppy. I have to replace the upper arms too.
    Sent from my SM-N920V using Audizine mobile app
