I didn't have time to wrestle the crank pulley off tonight but I did pull the upper timing cover and the inspection rubber out of the lower timing cover. What I found is a bit puzzling.
Chain tension up top is good and if I rotate the engine by hand it spins over smooth...mostly. Looking in the inspection port of the lower cover my tensioner is holding tension and if manually drive it back it pushes out again. What the?
What's concerning is the "mostly" part from up above. It spins over smooth by hand to a point and then it reaches a position where it jams up and doesn't want to rotate at all. Once when rotating I heard a god awful ratchet noise from under the cover.
Now I'm starting to wonder if I the problem is something else under there. I see the cam chain, the oil pump chain...but what is that chain on the right in this picture?
https://c8.staticflickr.com/8/7745/2...baf39d38_k.jpg
Next step is to get the lower TC off, obviously, but what God help me...what if everything looks fine in there?
