The A.R.T process impacts the micro structure of aluminum by utilizing three hydraulic rollers to apply pressure to form the inner rim area.
The rollers move down the barrel applying pressure to compress, stretch, and form the entire wheel barrel producing optimal weight savings while improving material strength.
This process actually alters the grain of the aluminum to produce a wheel barrel that is significantly lighter with enhanced strength comparable to fully forged wheels.
A.R.T helps reduce the weight up to 25% when compared to a standard cast wheel through this finer and more even aluminum structure.
M610 weights for 19” sizes start at 21 lbs/wheel while weights for 20” sizes start at 22 lbs/wheel.
Wheel Models: M610, M615, M621, M652
Bolt Patterns: 5x112, 5x114.3, 5x120, custom 5-lug available
Offset: Custom offset available
Finish Option:
- Bespoke Level 1: Single stage powdercoat
- Bespoke Level 2: Paint match
- Bespoke Level 3: Hand applied (Brushed, Polished, etc…)
M610 Sizes Available: 19x8.5 | 19x9.5 | 19x10 |19x11 | 20x9 | 20x10 | 20x11 | 20x12
M615 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10 | 22x9 | 22x10 | 22x10.5 | 22x11
M621 Sizes Available: 19x8.5 | 19x9.5 | 19x11 | 20x9 | 20x10 | 20x10.5 | 20x11 | 20x12
M652 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10
