Results 1 to 9 of 9
    Stage 2 Banner Advertiser Four Rings GetYourWheels's Avatar
    Jan 23 2014
    Santa Fe Springs
    Introducing Avant Garde Wheels A.R.T. M600-Series
    The A.R.T process impacts the micro structure of aluminum by utilizing three hydraulic rollers to apply pressure to form the inner rim area.
    The rollers move down the barrel applying pressure to compress, stretch, and form the entire wheel barrel producing optimal weight savings while improving material strength.
    This process actually alters the grain of the aluminum to produce a wheel barrel that is significantly lighter with enhanced strength comparable to fully forged wheels.
    A.R.T helps reduce the weight up to 25% when compared to a standard cast wheel through this finer and more even aluminum structure.
    M610 weights for 19” sizes start at 21 lbs/wheel while weights for 20” sizes start at 22 lbs/wheel.
    Wheel Models: M610, M615, M621, M652
    Bolt Patterns: 5x112, 5x114.3, 5x120, custom 5-lug available
    Offset: Custom offset available
    Finish Option:
    - Bespoke Level 1: Single stage powdercoat
    - Bespoke Level 2: Paint match
    - Bespoke Level 3: Hand applied (Brushed, Polished, etc…)
    M610 Sizes Available: 19x8.5 | 19x9.5 | 19x10 |19x11 | 20x9 | 20x10 | 20x11 | 20x12
    M615 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10 | 22x9 | 22x10 | 22x10.5 | 22x11
    M621 Sizes Available: 19x8.5 | 19x9.5 | 19x11 | 20x9 | 20x10 | 20x10.5 | 20x11 | 20x12
    M652 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10
    Email : [email protected] | Call or Text: (562)219-2525|
    Your Wheel Fitment Specialist / Wheel & Tire Deal via DM
    Top Tiers Dealers - Avant-Garde / KlassenID/ VSForged / Stance / Vossen + More
    Established Member Two Rings deewan's Avatar
    Mar 30 2016
    2013 Audi S4
    Cedar Rapids, IA
    When will these be up on the site so we can see some prices, availability or other options?
    2013 S4 S-Tronic Brilliant Black
    Premium Plus | RS4 Gloss Black Grill | LED Interior Lights | LED Fog Lamps | Alcantara | B&O | AWE Carbon Fiber Cold Air Intake
    I always use a little chewing gum on these rides. It filters out the pollutants. Of course you've got some good grillwork there to keep out the ozone. I gotta get this thing up to 95, uh, check out the fluorocarbon output.
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by deewan View Post
    prices should be 'out there' - either online or on Amazon even, just so you get an idea
    they're right in line with a lot of other flow forged options out there, less the brand premium you'd pay for Vossen or HRE FF's. i have a set of M610's on my car: light and a nice, brushed finish
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Jan 23 2014
    Santa Fe Springs
    Sorry about that, the wheels are so new we haven't had a chance to add to the website. Spoke to our web team and they should be up this week!
    Heres the finish options and I'll PM you with more info
    Quote Originally Posted by KRp220 View Post
    Glad you like your M610s!
    Share some photos of your setup if you can, would love to see it!
    Aug 23 2011
    NH
    These are the only pics I have now. 19x8.5 et 35 on PSS 255/35/19. I prefer the meatier look of the 255's on 8.5" wide wheel over the 9.5's I had previously, but I did give up some "stance". I'm hoping I can fit a 5mm spacer in the back.
    The wheels have a nice, brushed finish and a classic look while saving some weight too. More pics to come (eventually)
    Jan 23 2014
    Santa Fe Springs
    Those look fantastic, thanks for sharing!! Would love to see more photos when you have some available.
    Established Member Two Rings weaselp1's Avatar
    Apr 21 2016
    Milwaukee, WI
    What does one rim weigh? Thanks in advance!
    Sent from my SCH-I545 using Tapatalk
    2013 S4 Premium +
    GIAC Stage 2 and TCU
    Phantom Black Pearl, MMI, B&O, Alcantera, CF
    Eurocode AK & Sways, Moog End Links, CTS Turbo Intake, CR-15
    HRE FF01 19x8.5 ET45 with PSS 265/35/19 - Summer Setup
    Alzor 18x8 ET35 Rotor reps with Nokain R2 - Winter Setup
    Aug 23 2011
    NH
    Quote Originally Posted by weaselp1 View Post
    just over 23 lbs if i remember correctly
    Jan 23 2014
    Santa Fe Springs
    Yup, the 19" M610s are right around 23 lbs and 19" M652s are about 24lbs!
    A normal cast 19" usually comes in closer to 27-29lbs
    Let me know if you're interested in a set
