    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    How do you remove the interior panel for the trunk so you can access the hinges?
    Has anyone removed the interior panels for the trunk so you can access the hinges that guide the trunk lid for opening and closing?
    I just got it back from the shop and would not like to take it back there if I could help it. Someone hit me last month if you're wondering why it was there.
    Anyways, It opens and closes fine, except for when it finishes opening, right at the last maybe, 5% bit of it, it seems to let go of it and it doesn't open soft anymore. It's like it's opening too far.
    This outlines the parts I'm talking about:
    Any advice is appreciated!
    May 20 2010
    Assuming it's anything like a B7...
    Remove the 4 tie downs (chrome pieces, 2 screws each). Take out the spare wheel cover. The rear black panel there (that surrounds where the trunk latches) should be held in by a couple screws. Those need to be removed. At that point, the trim should pull out (may be tough because it's clipped in). Be aware that the passenger side has the 12 V line and cubby, so it will also have to pull kind of upwards until you disconnect the wiring. That should let you swing them out of the way, but not completely removed.
    To fully remove it, you'd have to remove the rear seats, IIRC.
    Or if the B8 is different, then I apologize for wasting your time.
    Oct 22 2012
    Markham
    for the driver side one, you just tug lightly and it comes out.
    Dec 15 2015
    Denver
    Alright, I'll be trying that! Thank you for the input!
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
