Thread: Door Shell
    Mar 13 2016
    Denver
    Door Shell
    Any DIY on to replace a door shell. Some asshole hit and run me and I don't have full coverage, plus I don't feel like dealing with my insurance company. But what tools would I need and how would take a part of the window regulator and stuff. Thanks in Advance
    Senior Member Three Rings JJ.'s Avatar
    May 22 2012
    Netherlands
    The entire window and frame is bolted in, so doorpanel of, frame out and disconnect the wiring. Remove the shell and swap the lock.
    Not to hard
    -Cactus green Audi S4 B5 on air
    Instagram: jj_dw
    Mar 13 2016
    Denver
    Quote Originally Posted by JJ. View Post
    Not to hard
    Okay thanks man !
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    its sort of a pain for the front doors cause the door harness doesn't unplug like the rear ones. so you have to fish the harness into the door and to its respective place. youll need some standard torx bits. something to cut zip ties and some screw drivers to bend the tabs to get the door handle/lock out. its not to bad but it is a pain in the ass. do not loose the shim on the lower part of the window frame. you should mark it before you take it apart or you'll have window frame gap problems. good luck man. be happy it wasn't much worse.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
