Results 1 to 10 of 10
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    we voted down emmission yet we still do them FML
    po172 bank 1 rich
    po175 bank 2 rich
    VAG CODE 17535 - P1127, 17537 - p1129 Both are system too rich
    it does not say anything else
    in the last year i did maf, purge valve, pcv, new bank 2 p2 and gas cap.
    I have a b7 s4 JHM 91 tune, piggy pipes aem carbonio intake box(yes i know its not as good as stock but looks better mmm carbon fiber)
    unsure where to start as i havent had an audi since 2002 and my b5 s4 got lemoned (7turbo blow outs)
    maybe clean MAF, i figured if it was an o2 id get more then one code per o2 as my b2p2 sensor set off 10 codes
    Cleaned MAF cleared and same codes came back...
    17535 - Fuel Trim; Bank 1 (Mult)
    P1127 - 002 - System too Rich - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194089 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3345 /min
    Load: 13.7 %
    Speed: 107.0 km/h
    Temperature: 96.0°C
    Temperature: 45.0°C
    Absolute Pres.: 820.0 mbar
    Voltage: 13.462 V
    17537 - Fuel Trim; Bank 2 (Mult)
    P1129 - 002 - System too Rich - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194090 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3198 /min
    Load: 27.8 %
    Speed: 102.0 km/h
    Temperature: 96.0°C
    Temperature: 45.0°C
    Voltage: 13.335 V
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Data logged a sanity check on your MAF?
    Checked your fuel trim measurement blocks to see if it's at idle or under throttle?
    - erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Jul 12 2012
    i pulled the codes while at someones house i dont own a Vag
    im sure thats what i would need to check those right
    could a broken Check Valve cause this mine will come apart but i can snap it back together unsure if its made to or not
    https://jhmotorsports.com/shop/catal...-s4-p-396.html
    here is the part i am unsure of
    Jul 03 2005
    Broomfield, CO
    * VW / Audi DTC 17535 (P1127) - Long Term Fuel Trim mult., Bank1 System too Rich
    * VW / Audi DTC 17537 (P1129) - Long Term Fuel Trim mult., Bank2 System too Rich
    As told by the fault codes, your Multiplicative fuel trim (fuel adjustment during all RPMs outside of idle) is too rich.
    This can be caused by a faulty pre-catalyst oxygen sensor, a faulty MAF, or an exhaust leak prior to the pre-cat O2 sensor.
    Doing a VAG-COM data log run of measuring blocks 002 (MAF), 015 & 016 (misfire counts), 032 (fuel trim, banks 1 & 2) will tell you a lot and could pinpoint what the failure is.
    - Erik
    Jul 12 2012
    I dont own Vag-com was using someones and currently dont have it. to be honest i am also unsure how to do a data log run of these items im a Vagcom noob
    Jul 03 2005
    Broomfield, CO
    If you head north to Broomfield, I can assist.
    Otherwise grab hold of a local member on your area with a VAG-COM to run such logs.
    - Erik
    Jul 12 2012
    i can come up there today other wise i normally have monday n sundays off that would be a great help
    Jul 03 2005
    Broomfield, CO
    Let's plan on this Sunday, July 3rd for it - say middle to late afternoon.
    I'll be in touch via PM later in the week for details.
    - Erik
    Jul 12 2012
    sounds good ill wait for the PM
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by Aok303 View Post
    PM sent - I'll see you tomorrow on Sunday, July 3rd.
    - Erik
