Results 1 to 34 of 34
    Senior Member Two Rings Muggerrudd's Avatar
    Apr 01 2014
    Cleveland Ohio
    Time to update suspension
    Ive been browsing the forum and haven't came across a post that really helps.
    My front tires keep wearing/cupping on the outside lip, both driver and passenger sides. I have had alignments, wheel balanced, new upper and lower control arms so im left with (Shocks & Struts).
    current mileage is around 127,000 miles
    What is a great suspension kit that includes all 4 Shocks and struts. This is a DD and being lowered isn't really important to me.
    2007 A4 2.0T QUATTRO
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    H&R springs + Bilstein Sports makes for a great ride quality and improvement for the occasional twisties 👍🏾
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by QuattriumMT6 View Post
    you replaced what didn't needed to be replaced. most importantly inner and outter tie rods for tire wear.
    Ivan
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Have you checked tie rods as well? That could be a cause for uneven and premature tire wear, especially on a car that's going up in milage as yours is.
    R:
    Apr 01 2014
    Cleveland Ohio
    my control arm bushings were shot. that why i replaced them.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Do you have adj upper control arms? Changed your tie rods well your in there too. What alignment specs are you getting?
    Apr 01 2014
    Cleveland Ohio
    when i replace the control arms, the tie rods looked/felt fine. they weren't loose or sloppy.
    most times when a tire starts to cup along the outside edge its normally due to excessive tire bounce due to blown struts or worn out shocks.
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Don't buy H&R street performance coilovers. I hate mine. They ride like ass.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Apr 01 2014
    Cleveland Ohio
    Aug 24 2013
    Stockton, CA
    Quote Originally Posted by dalmation53 View Post
    I was going off of what he had left listed to be replaced. He already mentioned he replaced the control arms otherwise I would have recommended the suspension refresh kit from FCPEuro. You're correct that shocks/springs alone don't fix the issue. I was just adding as a DD they make for a good replacement as the mild drop/good shock combo has been issue free for me since I've already replaced my controls arms/tie rods. With tire longevity in mind, getting toe as close to 0 helps significantly.
    Apr 24 2016
    California
    Replaced my front suspension with the FCP kit a week ago, $287 with the audizine promo code and came to $297.98 after shipping I think. Best money I ever spent it now drives like a brand new car 👍 Don't forget to get an alignment after a day or so for it to settle into place, and don't torque bolts until suspension is loaded.
    Apr 01 2014
    Cleveland Ohio
    Quote Originally Posted by RakkCity View Post
    You obviously don't know what this thread is about.... Smh
    Aug 20 2013
    Miami
    Quote Originally Posted by Muggerrudd View Post
    LOL let the man share his emotions hahaha. but yeah man you should replace tie rods anyways they are dirt cheap.
    Ivan
    Apr 01 2014
    Cleveland Ohio
    i have a set of them in my garage already. ill put them on while doing the strut assembly. Just need some options for suspension kits.
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    If you want height adjustment, I have these, like them a lot. I found them for about $100 cheaper than that.
    https://www.ecstuning.com/Audi-B7_A4....0T/ES2984056/
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Aug 24 2013
    Stockton, CA
    Are you particular about a certain brand/distributor? Do you fancy spring/shocks over Coilovers, etc? personally I'd prefer a higher quality spring/shock combo over a budget friendly set of Coilovers. I like you don't really care for height adjustability and drive my car pretty much everywhere regardless of the road conditions.
    Apr 01 2014
    Cleveland Ohio
    brand doesnt matter. something reliable. like i said its a DD and i rather have ride quality over height adjustable.
    Apr 24 2016
    California
    Figured for anyone reading this thinking about refreshing their parts could use a testimony. Lol this whole thread ain't about you bruh
    Aug 24 2013
    Stockton, CA
    The link you posted earlier is the same setup I'm currently on. Replaced my blown shocks with Bilsteins and it rides well especially with a full set of passengers.
    Jun 17 2013
    jersey city nj
    I ed ST coil overs about 2.5 years ago. Ride comparable to oem sport suspension. My St are at the highest setting. It drops it about 10mm. I have ZERO interest in being lowered. Living in the Tri-State area. Its pot hole city and Im riding on 19's with 255-35-19 tires. I have not ed any other new suspension components since Id own the car. Struts have not blown out, Ride is great imo. Give Chris@1552 a call. he has the prices around
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    I have had my STs for about 3 years now (and ~60k miles) and they have been great. Rear springs are a touch soft, but not too bad if you keep them raised up a bit. If control arms, tie rods, etc. have been dealt with STs are a good choice to replace the factory shocks and springs.
    -Adam
    Feb 16 2015
    Didnt you just snag that pair of Hypercos? Installing my STs and Hypercos this saturday.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Apr 01 2014
    Cleveland Ohio
    are these the ST's your talking about? https://www.ecstuning.com/b-suspensi...ng/90605~st50/
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Those are, and they can be had for a good bit cheaper than that if you look around a little. Aluthman helped me my coilovers and I went with the hyperco springs in the rear, and the ride is pretty damn nice for as low as I have them set haha
    2007 Porsche Cayman | 5MT
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by gonemtbiking View Post
    Yep, haven't installed them yet.
    Yes, but there are cheaper places to buy them. I've heard Chris@1552 has good prices.
    -Adam
    Jun 17 2013
    jersey city nj
    I got my when he was having the Black Friday promo. With the rebate it was to of a deal to turn down
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Ashtonts View Post
    Adam is definitely a type of guy with helping out other members
    Apr 01 2014
    Cleveland Ohio
    if the kit comes with rear coils, why buy and install Hypercos?
    Jan 17 2015
    The hypercos are waaaay less bouncy and it helps you not rub over every little bump if you're really low.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    I have the STs on my B7A4 Avant and love the way they ride. I have them set almost all the way up and the ride is great and I have 60k miles on them. PM coming.
    Feb 08 2012
    Dallas, GA
    I concur on this. I haven't installed them yet either so I can't talk about the ride, but Chris was a stand-up guy to deal with and had the best price I could find.
    Jun 17 2013
    jersey city nj
    Some members say that it rubs when really lowered. I dont have that problem and you probably wont either because your not interested in slamming your car down to the subframe. I got the St's ed for the performance more then just the for being lowered
    Apr 01 2014
    Cleveland Ohio
    how do you accurately set the height from side to side? count turns or measure Fender to ground?
    Jun 17 2013
    jersey city nj
    Measure from ground to fender. Some people even measure with dead weight (their weight) in drivers front seat to simulate it loaded to even it out under load. Then accordingly.
