Results 1 to 6 of 6
    Jul 11 2011
    2021 Ford F-150 Lariat PowerBoost
    High Elevation S3 ECU Tunes Check-in
    Looking at a stage 1 tune soon and as those of you know who drive the S3 at higher elevations (>5000') the turbo lag can be pretty bad. Who noticed the largest reduction in lag with their tune? Anything else that you did that helped with lag?
    I'm kind of tired of using LC just to get a jump on a minivan at stoplights when I need to change lanes in a short distance...
    2022 /SQ7 P+ | Daytona Grey Metallic | Executive Pack | Carbon Inlays | Driver Assistance | EA825 4.0T (IYKYK)
    APR Stage 1 685+ HP (Planned)
    Gone But Not Forgotten
    C7.5 S6 - Moonlight Blue
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    2008 V10 TDI Touareg II - Floret Silver
    2006 V10 TDI Touareg - Reed Green
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by CJ_S4 View Post
    Tune helped, as well as the DSG tune. Opening up the intake restriction and doing a turbo muffler delete will help with throttle response/lag. In regards to the intake, you can modify the stock intake by removing the rain tray in the box, add a K&N or other filter and modify the air scoop in the front to flow air on the drivers side or just buy an entire intake.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Junior Member One Ring
    Sep 08 2015
    Currently running the United Motorsports 'red' file for both the ECU and DSG. HW mods include APR intake, CTS turbo muffler delete and CTS catted downpipe. If I were doing it again, I might save my money on the intake and turbo muffler delete, doing only the downpipe - that is where I felt the biggest difference.
    Aug 28 2013
    Quote Originally Posted by SirScott View Post
    I think intake mods will help his situation as at high elevation as the engine is starving for air. Any relief in restriction should help somewhat.
    Sep 08 2015
    Quote Originally Posted by Baggio View Post
    I'm in the same location.
    Aug 28 2013
    Oops, I missed that.
