I have been here for a little while, but I have never made a build thread. Figured I would start.
This is my B6 S4 that I call the Pig. I am very fond of the car, it is really quite capable and well balanced for a sedan. I bought it as a weekend car for doing some racing with the capability of taking car seats in the back... lately though it is mostly just a track car as I have a Q7 for a daily.
Bought it in September of 2014, it was stock aside from a magna flow cat back, with 97,000 kms on it
Got to rebuilding the entire car over the winter
- Rottform NUE 18x9.5 with 245/40 PSS
- JHM ECU remap 91 oct
- JHM Intake heater bypass
- Trexturk 2.5" catless downpipes
- Magnaflow catback (thank you previous owner)
- 034 density control arms kit (get rid of the squeeks)
- 034 zero gap snub mount w/ bushing
- 034 Density Transmission mount
- 034 Motorsport engine mounts
- 034 88mm throttle hose
- 034 strut mounts
- H&R Coilovers
- Cupra R lip
- 034 Solid rear sway bar w/Adjustable sway bar end links
- 034 All metal Tie rod ends
- Apikol Diff mount (race)
- 034 wheel stud conversion kit
- 034 adjustable rear control arms
- Front ECS Lightweight two piece rotors - Cross drilled, slotted and larger vents %25 lighter than stock.
- EBC Red stuff *(kevlar ceramic) for front and back
- Raxles (RR Axle) (previous owner had bent one rear axle somehow, the car would shake above 100 km/hr)
- ECS Stainless Steel brake lines kit
- Motul RBF 600 fluid
- ECS Rear diff service Kit with Motul 300 - 75w90 and magnetic plugs
- Bentley (handy to have)
- ECS trans Service kit
- JHM Light Weight Crank Pulley
- JHM Shifter trio Package
- JHM auto tensioning pulley
- 034 Adjustable front control arms
- JHM 5R clutch kit /034 LW flywheel
- Enkei RPF01's 18X8 with 245/40/18 PSS and now 235/40 Sport cup 2's (track)
I have a lot more parts but I am too lazy to write out it all. Planning on a timing service this winter, and a JHM blower for this fall.
The spare block is getting sleeved, then rods and pistons buy a local shop.
Street mode
Some of the build photos
Track mode
Spare block getting prepped for some work :D
Nitrous install
Tucked away for a clean look
Corner weights and balance specs
Track Days:
Video of the piggy chasing down a 458 in the wet. (its point to pass so the S5 slowed me down)
http://vid48.photobucket.com/albums/...psa6ujldzw.mp4
Drag racing:
Ran 13.50 in 3000 DA
http://*******************/uploads/p...l4vvkM0TUR.jpg
I might part ways with the nitrous if anyone is interested, currently installed on the car, but I will be pulling it shortly. If it doesn't sell, I am going to run it on the new block with the blower.
