Results 1 to 15 of 15
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! ECS Performance Pendulum Mount Kits | 8V A3/S3
    Designed and manufactured in the USA using the most current design methods and materials, ECS Performance Drivetrain Mounts utilize a perfected polyurethane formula to deliver smooth power transfer through the driveline to the ground while minimizing chassis feedback.
    The custom-machined Pendulum mount is a highlight of this latest ECS release. All-weather seals capture a teflon-lined spherical bearing that replaces the poorly designed factory bushing, eliminating front bushing deflection and premature failure.
    Features include:
    • Designed and manufactured in the U.S.A
    • Custom machined Billet 6061-T6 Aluminum construction
    • Stainless Steel, Teflon-Lined Spherical Bearing
    • Anodized black for a great appearance and corrosion resistance
    • Genuine Torque-to-Yield fasteners are included for proper installation.
    Handle the Push & Pull
    Fitment:
    Audi 8V A3/S3 1.8T/2.0T (2015+)
    Be sure to check out our -----> Installation PDF <-----
    Jason
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    With the differences in inserts for some S3/A3/TT does this take that into consideration or does it not matter?
    Do you mind sharing the brand or manf of the bearing? Aurora? McGill?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Nov 13 2009
    the OC, SOCAL
    do you have a comparison between the stock pendulum mount vs yours (ES#3135673)?
    ( I'm not talking about the insert which has been discussed before with other makers)
    I'm curious if there is any performance differences other than it being made of billet aluminum. will it help stiffen up the area more than stock and how if it does.
    I hope I can feel something with these.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by aaronz View Post
    No difference between models/chassis.
    Unfortunately which manufacture we use for our bearing is proprietary.
    Jason
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by 949 View Post
    Billet aluminum is much more sturdy than the factory piece. The biggest difference is the use of a Spherical Bearing rather than a rubber bushing. Rubber can deteriorate, rip, tear etc. where a sealed bearing will not. This also provides a much more solid mount. It even has its own all weather seals that capture the spherical bearing to keep the elements out and keep the bearing operating maintenance-free.
    I hope this helps!
    Jason
    Nov 13 2009
    the OC, SOCAL
    so once I install it ill feel an improvement right away?
    what is the original part made of? I thought it was steel.
    I can see that the spherical bearing is a plus. if that make a difference I maybe down for this part.
    I already have the 034 dogbone insert. that I felt right away.
    Oct 02 2006
    Wadsworth,OH
    Steel. You really wouldn't notice a difference between what material the brace is made from. But I will say Billet Aluminum is stronger. So you're increasing the strength of the brace by making it out of a different material.
    The bearing will absolutely make a difference. You're replacing a rubber bushing with a solid bearing.
    Jason
    Nov 13 2009
    the OC, SOCAL
    then I'm sold on the bushing part.
    the aluminum reasoning is a bit a stretch (J/K pun intended) for me. it does look really nice but its under the car so it wont help with the looks unless I tell everyone to lay on their stomachs and take a peak.
    Oct 02 2006
    Wadsworth,OH
    Just about every piece that's beefed up in race/track cars is made from billet aluminum, at least that I can think of. It must be the material of choice for a reason.
    Jason
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by reyoasian View Post
    wonder how that dogbone insert compares with the 034 one. also whether the poly insert helps with reducing vibrations
    We designed our insert to be firm but with minimal NVH transfer. Which is the reason for the 2-piece design. Poly still offers some damping ability unlike a totally solid insert.
    It's the best of both worlds honestly.
    Jason
    Feb 18 2016
    Infiniti QX60
    SD
    WOOT!! Glad I waited, I was hoping someone would release something like this. Just placed my order. Great work.
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by hbracer93 View Post
    make sure you give us a full review. I'm very curious if you can feel anything since all we are seeing different is the spherical bearing. if there is a for sure tighter feel ill order one. real itching to mod something on this car to make it a tighter drive.
    Feb 18 2016
    Infiniti QX60
    SD
    Unfortunately I won't be able to install it till November which is when I get to my car. It will be joined by my air ride suspension also.
    Oct 02 2006
    Wadsworth,OH
    Thanks for the order!
    Jason
    Nov 13 2009
    the OC, SOCAL
    pretty tempted to get this part but the item wont ship till july 5th and there isn't any discount for early buyers.
    so I can wait till there are some reviews from users for now.
